What would be a good spacer size for 2014 gs350 f sport?
Need spacers what size to be flush and will it effect my car? Getting new tires tomorrow and I want the spacers with out having to order if possible... North Carolina..
I am running 20mm rear and tires are almost fully flush. 25mm would probably do it. 15mm for fronts is what I've read across the forum. You'll need longer studs probably for the rear (not sure about front) unless you are planning to use a hub style one with its own studs.
This is with stock F sport 19s.
GSapo (09-06-24)
I am running 20mm all around and they look perfect to my eyes. There is a tiny bit of rubbing at full lock on the front. You could probably run 15mm front that might get rid of the rubbing, but the 20mm look awesome.
H&R DRM Spacers have their own studs, no need to worry about length.
front: 15mm 3065602
rear: 20mm 4065600
Looks like this:
front: 15mm 3065602
rear: 20mm 4065600
Looks like this:
Mine are H&R
for you guys who have installed 15mm up front - did you have any rubbing? I recently installed 15mm's and their is minor rubbing when half locked right/left...
Former Sponsor
15mm is usually the way to go in order to avoid rubbing. If you want 20mm, I have a full set of Eibachs that were test fit then removed. I will sell them for $200
Here's the H&R TRAK+ DRM Wheel Spacers .. they are from the RAV4 application.
