Can I just go to the dealership and order from them? Is it even possible?
Originally Posted by thomi
okay after putting all the wires together, would I need some type of resistor for the led of any sort so the led lights won’t be blown from too much power?? And I won’t be running the arduino and can shield, so I won’t plug in wires 23&24
I am interested in the triple beam from a cosmetic view not sure how it will actually affect night time visibility.
if you don’t plug 23&24, your lights will not work properly-they need CAN to be operated, not direct current input as in the old headlights. see my previous posts. Headlight ECM is controlling all LEDs voltage.
That's weird. The OEM triple beam lights on my GS never turned side to side. They had the auto leveling stuff, and that was it.
My new 16+ triple beams do not turn sides as well. Andrew (Russian guy) says, that new triple beams have corner lighting but not mechanical (like 13-15 LEDs): it does it with additional LEDs trip lighting. However, again, I did not notice that.
Triplebeams with AHS have corner lighting, for sure (you can see this on Andrew's video here https://www.drive2.ru/l/534654297632145901/
Maybe, that's the regional specs? Does anyone have proofs that European triple beams without AHS have corner lighting?
hey I need some help, just bought some GSF triple beam headlights for my 2013 GS350 luxury pkg and wondering if it’s plug and play or do I need some type of modifications. If you can add me on IG to message easier there, @nguyenthomi
Yes you can if you order them. You'd better have deep pockets and be prepared for the price.
Just for ****s and giggles I went to my local Lexus dealership and I was quoted $3,452 for each triple beam assembly light. That price didn't even include all the other components like washers, mounts, screws, fender parts, etc.. No thanks.
