Can I upgrade Rotors from 1 piece to 2 Piece?
Hello Everyone,
I am looking for confirmation on my rotor upgrade. My dealer is not much help on this.
I have a 2013 450h with the one piece front rotors and need rotors/pads and would like to get the 2 piece OEM F-Sport rotors. Can someone please tell me if this is compatible with my gs and any parts needed outside of rotors/pads?
Are the rear rotors the same for F-Sport and standard GS?
Thank you
Thank you
I am new here and don't have much to offer beyond the cliche "do a search" that I mean with no I'll will. I am pretty sure you will find that many folks have moved away from the two piece rotors due to noise.
I have searched the forum about the OEM 1 and 2 piece rotors and have not found confirmation that the rotors/pads are interchangeable. I also am not looking for the 2 piece for aesthetics. The 2 piece are better as they are lighter and have reduced fade, hence the reason Lexus puts them on the f sports. I saw the clicking issue and that does not scare me off.
I like OEM and do not want to go aftermarket.
Just need to know if the rotors and pads are interchangeable. Thanks again.
I think the non-F brakes are around 13 inch and the F's are 14. Guessing you would need new calipers/brackets/and maybe even knuckles/hubs. I would start by cross referencing all relevant part numbers between F and non-F before going further.
The rotors and pads are not interchangeable in the stock configuration. At a minimum you would need new knuckles, hubs, and calipers. You might even need different wheels as well due to clearance issues of a bigger brake setup. By the time you pieced this together you will probably spend the same amount of money, spend a lot more time, and have a worse performing product than if you would have just bought a quality Wilwood/Brembo/APRacing big brake kit to begin with. I understand wanting to stay with OEM parts but since they weren't engineered for your platform in the first place, what's the point?
FYI - The performance gains you mentioned as your motivation to pursue this swap won't be noticed anywhere outside of a track or SERIOUS canyon carving type of environment; your money would be significantly better spent buying the best tires you can afford.
Im2bz2p345 (12-02-20)
Hello Everyone,
Thank you
Thank you
Thank you for the input. I do not want to go that far into brake mods. The brakes are quite good on my 450h but the front rotors are now a bit warped as I do drive it hard. With the extra weight of the 450h I thought I could move up to the f sport brake setup easier and prevent future hard driving brake issues.
![Driving Skid](https://www.clublexus.com/forums/images/smilies/drivingskid.gif)
TnGS350
11-14-18 07:45 PM
