2016 Lexus GS 350 Base Triple Beam Headlight
Old 04-23-20, 09:54 PM
Chungvatra
Chungvatra's Avatar
My result:
The following 3 users liked this post by Chungvatra:
escriche31 (04-24-20), lexus4jess (05-08-21), thisguy_06 (04-24-20)
Old 06-05-20, 09:38 PM
Saff
Saff's Avatar
Default 2016 Lexus GSF triple beam headlight
Originally Posted by escriche31
Hi,
I swapped out my single beam LED headlights on my 2016 Lexus GS 350 Base for the Triple Beam (GS F Headlights) i am having issues with my High Beams and also instead of the DRL's staying on alone the entire headlight is on even if i switch it to the off position, does anyone have any recommendations on how to get this fixed?
please respond as I have the same problem, I bought two used triple beam headlights with brand new ballasts from the dealer. I can’t get my high beams to work and switch my drl to stay on. When I start the car everything stays on. Am I missing a part or module that’s controls the high beams and switch?
Old 06-06-20, 06:51 AM
escriche31
escriche31's Avatar
Default Hello
Hey there a user by the name of Chungvatra he got it done I never got mine to work, sold the GS.
QUOTE=Saff;10819772]please respond as I have the same problem, I bought two used triple beam headlights with brand new ballasts from the dealer. I can’t get my high beams to work and switch my drl to stay on. When I start the car everything stays on. Am I missing a part or module that’s controls the high beams and switch?[/QUOTE]
Old 06-22-20, 07:36 PM
DeneAlex
DeneAlex's Avatar
Hi,
If the lights are always on, they are probably in the error mode. Techstream can tell, what is missing. Assuming you purchased new headlight ECMs for each headlight, all you need is to initialize the AFS in those ECMs. You can do it using Techstream
lexus4jess (02-06-22)
Old 09-02-20, 11:01 AM
sfarrell27
sfarrell27's Avatar
hi do you still have the headlights?
Old 09-04-20, 12:11 PM
eddie420
eddie420's Avatar
Hello! If he does, he will post them in the marketplace, located here: https://www.clublexus.com/forums/market/
Old 05-16-21, 05:27 AM
Mahrez
Mahrez's Avatar
what is the part No of this headlight you purchased?
Old 09-30-21, 12:03 PM
Mahrez
Mahrez's Avatar
Hi,
Have you find the solution? please help
Old 01-23-22, 09:27 AM
Gary350F
10th Gear
Gary350F's Avatar
Saff, did you ever get your triple beam headlights to work? Am thinking of making the conversion as well.
Old 02-06-22, 01:44 PM
lexus4jess
lexus4jess's Avatar
Originally Posted by DeneAlex
Hi,
My mechanic used his Techstream to get my lights to work correctly. high beams and DRL work fine.
Old 05-23-23, 10:45 AM
fsportchris
1st Gear
fsportchris's Avatar
Hi Armush0907,
I purchased the headlights on eBay I paid about $2100 plus I purchased 2 led modules from the dealership which about $230 each, but there is a part that no one was able to give a part number that controls the headlights and I was unable to make function correctly (no high beams and the light would always stay if the engine was running) I since upgraded to an F-sport and have the headlight in a box if you like I can sell them to you. Also did you find anything that would make them work properly?
Hi, long shot but just came by this thread. Are you still looking to getting rid of the headlights and modules?
I looked into the capability to have the triple beams work properly is the OEM ballast that comes with the car.
Thank you
Old 05-25-23, 04:36 AM
jeffe005
10th Gear
jeffe005's Avatar
Thank you
hi I still have the same problem with my headlight and the techstream can’t fixed it only said this
Old 06-06-23, 06:56 PM
jaypeng617
3rd Gear
jaypeng617's Avatar
Do you realize the triple beam headlights you bought off eBay are not OEM? They are knock-off replicas made in China. Don't expect to get the full package off a $2100 vs $7000 OEM. Lexus is selling each headlight for $3500 each. 😂
Maybe this help.
Lexus GS to GS-F conversion headlight harness
Want to swap out the led headlights to the new Triple beam headlights. This harness does just that. Connects directly to your headlight ECU's and runs the cables to your cabin to connect to your vehicle.
Please note: this is not a plug and play kit. you still need to cut and solder wires.
RCMike
RC - 1st Gen (2015-present)
12-11-17 07:38 AM
drseth
Lighting
06-10-17 03:11 AM
cheuhpeuhh
06-17-15 07:11 PM
actv8d
11-09-10 08:00 PM
LexISguy
RX - 3rd Gen (2010-2015)
17
08-18-10 11:29 PM
Quick Reply: 2016 Lexus GS 350 Base Triple Beam Headlight
