Looking to fit 20x11 rear wheels w/o rubbing. Thoughts?
2016 Lexus GS-f 20x10.5 front 20x11.5 rear
Time for some new wheels and thinking about going 20x11 rear rotary flow forged wheels for the extra concavity along with 9.5" or maybe even 10" wide front wheels. My car is currently sitting on RSR SuperDown springs which is about 2" drop all around. Will also need to adjust accordingly with proper tire size + offset to clear.
Has anyone pulled off running these size spec wheels: 20x9.5 or 20x10 (F) + 20x11 (R) on their 4GS?
If so, what offset + tire size for both front & rear wheels is ideal with these specs as flush or slight poke as possible w/o rubbing?
Hello I have 20x10.5 +25 in the front 20x11.5 +30 in the rear, stock suspension no modifications no rubbing, 245/35/20 front 275/35/20 rears.
You have all that wheel and such small tires.
Also, you have a GSF, which can accommodate wider wheels/tires than a GS
jjbenzo
08-03-07 12:01 PM
