14’ GS350 F Sport thrown rod
#31
Yeah but the thing you’re not understanding is that it was not in my hands when such thing happened. I also know for a fact it was not the GM dealership because I actually work there. The vehicle was brought up from a different dealer. The only thing that makes sense to me is that vehicle had been in a accident or something and they took it to Joe Blow’s body shop privately and had a private shop do work to it so the factory warranty is not voided and to keep the car fax clean and then trade it off.
I believe you when you say that whatever engine work was done to your car's engine was done prior to you buying the car from the GM dealer where you are employed. Your issue is with the GM dealership that sold you the car...and where you are employed, not with Lexus. The GM dealer, where you are employed, sold you a car that was worked on by someone previous to you purchasing the car - that engine work Lexus believes was the ultimate cause for the engine to fail.
What makes you think the car was in an accident and needed body work? I thought it was just the engine (with a thrown piston rod) that was the issue with the car.
Why would a GM dealer buy a Lexus vehicle from some other dealer to put on their used car lot for sale? I'll give you time for a couple of guesses...
#32
Changing your own oil, or having an independent change it, does not void a car warranty. At worst, Lexus could ask you to demonstrate how you changed the oil yourself, or ask for receipts. Anytime, anywhere...
#35
615Kham
It sounds like you are having a two-sided problem understanding (accepting) why Lexus is refusing to honor the warranty on your engine. You are actually caught in the middle of a difficult situation.
On one side of this issue (and totally unknown to you) the car that a GM dealer sold you had extensive engine work performed on it, to the degree or extent that Lexus believes the engine can no longer be warranted by them...and was likely (at least) the reason the engine failed. You cannot blame Lexus for not wanting to take ownership of continuing to warrant an engine that some unknown non-Lexus mechanic has clearly delved deeply into the engine for some totally unknown reason to begin with.
On the other side of this issue is making the GM dealer (where you are employed) to take ownership of this engine failure problem, either with or without, the third-party warranty coverage you say your car is provided with through the GM dealer that sold you the car. As I understand it, this third-party warranty (through the GM dealer) only begins after the original manufacturer's (Lexus) warranty expires...but Lexus has revoked its warranty on the engine due to extensive and inferior work having been performed at some time prior to engine failure.
I believe your battle should clearly be with the GM dealer if Lexus continues to maintain its firm stand that warranty is denied on your car's engine. It was the GM dealer that sold you a vehicle that the original manufacturer (Lexus) has denied its engine warranty due to inferior engine work having been performed by a non-Lexus mechanic at some point in the past.
It's only reasonable that a manufacturer (in this case Lexus) should not be held responsible for inferior work performed by someone outside their jurisdiction. Accordingly, it was the GM dealer that either knew, or should have known, the history of this car that they purchased from another dealer and then sold to you. It was the GM dealer that chose to (according to you) purchase this vehicle from some other dealer and put it on their lot for sale. Should the GM dealer that sold you the car have known before they purchased it for re-sale themselves, that the original manufacturer (Lexus) would likely deny warranty on the engine if a catastrophic failure happened? The answer is: YES! It is a reasonable expectation that the GM dealer should have known about the extensive engine work, and if they overlooked this fact or the car's history (or intentionally did not care to learn about the car), that is a negligent gamble they decided to take. A gamble that should cost them (the GM dealer that sold you the car) whatever is necessary to repair or replace the engine.
#36
Unless someone is going to throw the towel and compromise, the outcome of this case is going to be very fact specific. Right now, you're basing a lot of of what you know based on what Lexus corporate, the Lexus dealer, and what the selling GM dealer is telling you. Obviously, each party is going to tell you their assessment of the situation that's beneficial for them. Unless I missed something in your prior posts, you have had not had your vehicle personally inspected by someone who has the proper expertise, who works for you. And no, I'm not talking about the typical trusted mechanic we all see but someone that's done a lot more work in looking at your specific engine, perhaps including or just short of a engine tear down to really see what's going on here.
In short, I don't think you have all of the details. It's easy to say that the selling dealer should have known about the engine problem. Yet, it's also easy for GM to say that you purchased the vehicle as-is. Then comes the Lexus dealership saying this and that..... but have their assessment been documented? Did they take photographs of the gasket or questionable spark plugs?
There's a lot of facts missing here. Unfortunately, it's going to be a situation where you're going to have to lawyer up and have him/her retain the appropriate experts to fight this case.
#37
Actually I’m sure a lawyer would. Oh and by the way I’m talking about going after the dealership that sold it to me. Due to the fact they were able to put a lifetime powertrain warranty (that’s not even in effect until the factory powertrain warranty is up) on it and a Bumper to bumper platinum wrap for the vehicle, if it has been “tampered” with. I purchased the vehicle in good faith.
#38
You are employed at the GM dealership that sold you the car that they got from some other dealer! Wow!
#39
OK, let's be clear here... did the dealer actually make the warranty themselves (doubtful), or was a third party extended warranty included with the purchase, or was purchased along with the car? In either case, you've got to read the entire contract to determine if the GS is eligible for coverage. Why don't you scan and post a clear legible copy of the warranty contract? I'll be happy to chime in...
#40
I’m thinking the same thing as most of you guys are, There’s more to the story than is being told because These “facts” the dealership are pointing out just don’t add up.
#41
At CL you will find a community that’s willing to help, but you need to be straight with the facts and use all the tools you’re given, including your eyes and brain, and not just your ears. What contract did you enter into? How do you positively KNOW the restrictions on the warranty unless you’ve reviewed it yourself? Do you trust your dealer to be as trustworthy as God, because we’ll all tell you, by and large, dealerships’ salespeople are likely heading to a much warmer climate when they leave this plane of existence.
At the very minimum, if you purchased a warranty that’s useless, the least you can do is request a refund. If Lexus denied your coverage now, there’s very little chance that your warranty will ever offer any coverage in the future. But don’t take my word for it... read your contract.
At this point we may only be able to help you mitigate your costs, you’ve got an uphill battle getting anyone to cover the repairs... unless of course, your dealer sits at the right hand of the Big Guy...
... or maybe as an employee you will luck out and get some goodwill from your employer, but not likely since you’re talking about lawyering up.
Sorry to be so harsh but we live in a “consumer-be-aware” society, especially today. Good luck, I hope it turns out better for you than my pessimism anticipates.
maclem8223 (06-10-19)
#44
This is a perfect example of why you should be extremely careful when buying a vehicle from a dealership that is not the same brand as the vehicle you are buying...or when buying from an independent used car lot. Many times the vehicles they sell, that are not their dealership brand, come with shady backgrounds.
