4th gen GS Oil Catch Can installed
Old 06-07-19 | 12:45 PM
PlPete's Avatar
PlPete
Between that and a timing chain it's a pretty proven platform. Not the most powerful engine out there but more than enough to get you in trouble. Seems like there isn't much you can do to it in terms of performance aside from an exhaust. Anything else you're better off with a different car or a GSF. Put it in Sport+ mode and enjoy it for what it is! A dependable well handling sports sedan.
The following 2 users liked this post by PlPete:
Markw4mms (12-15-19), RichardB23 (06-07-19)
Old 06-07-19 | 01:24 PM
praetor's Avatar
praetor
It's to catch all the snake oil people add to their cars.
The following 3 users liked this post by praetor:
Byprodrive (12-16-19), Lend0 (06-07-19), RichardB23 (06-07-19)
Old 06-07-19 | 03:12 PM
RichardB23's Avatar
RichardB23
That snake oil adds 13.2WHP
Old 06-07-19 | 09:18 PM
bob256k's Avatar
bob256k
Let me know if any oil is on your catch can after 5k.
Old 06-08-19 | 09:17 AM
kh4nh's Avatar
kh4nh
I am glad our engines reduce carbon build up via the working of the port injectors. There will still be oil blow by, given not as much since its not forced induction. I wouldn’t want the oil reburned, snake oil or otherwise haha
bob256k (06-14-19)
Old 06-08-19 | 11:29 AM
kode3's Avatar
kode3
I installed one in my 2011 Nissan Frontier 4.0 V6, it made a difference and collected 1/3 quart every 7500 miles. The engine ran smoother and a high temp ping it had during summer is gone, truck had ~70k miles when I installed and roughly ~130k now.
bob256k (06-14-19)
Old 06-08-19 | 12:07 PM
bclexus's Avatar
bclexus
Everybody place your order for a Catch Can! You don't want to be caught without one on your GS 350!
Cal916 (12-15-19)
Old 06-10-19 | 11:47 AM
jonathancl's Avatar
jonathancl
I just like the idea of having a pot scrubber catch oil in my fancy engine.
Old 06-14-19 | 10:40 AM
kjDE's Avatar
kjDE
If one is trying to avoid carbon build up perhaps using only Top Tier gasoline would be a good idea. An independent lab AAA hired showed it really works. https://gasprices.aaa.com/fuel-quality/
Old 06-14-19 | 11:48 AM
ChronoR's Avatar
ChronoR
That's not applicable to the carbon coking on DI engines that we're talking about here. The fuel never gets to hit the back of the valves so even the most detergent laden fuel won't help.
bob256k (06-14-19)
Old 06-14-19 | 12:07 PM
bob256k's Avatar
bob256k
Thumbs up
FINALLY someone who gets it! The coking happens at the BACK of the valves. I'm sure lexus did their absolute best after the 3gs issues, but if i can prevent oil from getting into my combustion chamber i will. To OP who installed a oil can let me know if anything is caught . To the rest of the keyboard warriors who do not have one, dont care or think it's bunk , (which it could be) shut up and leave please. No one cares about your opinion. Here's you non-PC moment for the day.
Old 06-14-19 | 12:09 PM
ChronoR's Avatar
ChronoR
To be fair, all the 4GS with the 3.5L V6 engines do spray fuel on the back of the valves. It's the special perk of Lexus's dual-injection system.
From what I hear though, certain driving patterns doesn't engage the port injection often enough to fully prevent the carbon coking but it generally works very well and some newer DI engines from other manufacturers do the same thing now.
Old 06-14-19 | 12:16 PM
bob256k's Avatar
bob256k
So if you drive slow like my other half and never go about 3k in eco mode, you might get coking?
Old 06-14-19 | 12:23 PM
JDR76's Avatar
JDR76
No, not really. The Toyota system uses both port and direction at low load and low RPMs.
The ultimate strategy is combining both PI and DI benefits, using each to diminish the other’s negatives. Toyota, for example, fires both injectors during low to medium load and rpm conditions—in other words, during normal driving.
Source
And as noted up-thread, the 2GR-FKS (GS350, 2016 and on) has a self cleaning cycle.
“When you go into a hot-idle situation, the system is going to look at the time that it ran, the number of cycles the injectors went through, the temperature of the injectors and then it goes into a self-cleaning mode,” Sweers says. “Because we have the port injection, I can continue idling the engine without having any side effects.”
Source
taniner (06-28-24)
Old 06-14-19 | 01:01 PM
bob256k's Avatar
bob256k
Do you have any detail about the 2gr-fse? I have a 2015 4gs
Quick Reply: 4th gen GS Oil Catch Can installed
