First gear
Old 06-23-19 | 02:17 PM
RichardB23's Avatar
RichardB23
Default First gear
So this has happened twice now. First time I was at a light and when the light turned green I tried to go but it seemed the car was in first and only slightly engaged before I felt what I thought was a love tap but it was the car jerking forward assuming gear caught. Second time was today I was in sport plus and manual and the car felt sluggish and then jerked again. Is this a common issue or is this a transmission issue I should be really worried about?
Old 06-23-19 | 06:44 PM
NebulaGrey's Avatar
NebulaGrey
Nothing like that on my 13 rwd f sport.
Old 06-23-19 | 06:45 PM
modad's Avatar
modad
I had the car hesitate on takeoff a couple of times and then got a warning that said: "Accelerator and Brake Pedals Depressed Simultaneously". After I realized what I was doing it has never happened again.
Old 06-24-19 | 07:07 AM
RichardB23's Avatar
RichardB23
But I don’t left foot brake and when it does decide to take off it’s a sudden jerk.
Old 06-24-19 | 04:45 PM
chinee's Avatar
chinee
What he means is that sometime your right foot might be touching both pedals... it's happened to me before as well.
The following 2 users liked this post by chinee:
modad (06-25-19), RichardB23 (06-25-19)
Old 06-25-19 | 08:35 AM
RichardB23's Avatar
RichardB23
Ah ok. I guess i'll pay more attention and watch to see if it happens again.
Old 09-23-19 | 07:27 AM
RichardB23's Avatar
RichardB23
So the ol gal did it again. Got to a redlight and when it turned green i tried to go as usual however it just revved so i checked my footing and shifted it into manual and it was still revving and i had to put it in neutral then back to drive to get her going.
Old 09-23-19 | 07:48 AM
chinee's Avatar
chinee
That is odd. What year is GS? Do you know if the the transmission fluid was ever changed? Sound like it could be either a sensor in the gear selector, tranny or low fluid. Unfortunately you’re the first person I’m seeing report this.
Old 09-23-19 | 07:59 AM
RichardB23's Avatar
RichardB23
2015 GS F-Sport that i bought used at the beginning of the year. I guess i'll bring it up to my service guy when i bring it in for an oil change in a couple of weeks. I'm hoping tis nothing major as this is my first lexus.
Old 09-23-19 | 08:21 AM
chinee's Avatar
chinee
Intermittent problems are the absolute worst to deal with. There might be a code, not all codes cause the check engine light to come on. Got a code scanner?
Good luck!
RichardB23 (09-23-19)
Old 09-23-19 | 08:30 AM
RichardB23's Avatar
RichardB23
Good luck!
I Dont but ill have autozone scan it this weekend just incase when i get pick up some 3m tape for the lip and roof spoiler.
Thank!
Old 09-23-19 | 09:26 AM
chinee's Avatar
chinee
Got this one from Amazon a couple of years ago, even provides live data. For $42, it paid for itself 3x over the first time I changed the TPS in my Sequoia.
Foxwell NT201 Auto OBD2 Scanner Check Car Engine Light Fault Code Reader OBD II Diagnostic Scan Tool(New Version)
Amazon Amazon
Old 09-23-19 | 09:49 AM
bclexus's Avatar
bclexus
It sounds like the torque converter is not always locking-up when you increase engine RPM when in-gear, which typically pertains to the torque converter or the level of ATF, however the problem could be any number of a wide list of things, e.g. a solenoid, a sensor, a control switch, the torque converter, the ATF oil pump, etc., etc. Let us know if any codes are listed, and what the code numbers are.
Hopefully you will see a Diagnostic Trouble Code like one of the following that pertains to the transmission (which will tell the technician exactly what the problem is):
P0705
P0711
P0712
P0713
P0717
P0722
P0729
P0748
P0751
P0756
P0761
P0766
P0776
P0778
P0781
P0894
P0973
P0974
P0976
P0977
P0979
P0980
P0982
P0983
P0985
P0986
P2714
P2716
P2757
P2759
Old 09-23-19 | 10:05 AM
RichardB23's Avatar
RichardB23
Will definately let you guys know.
Old 09-23-19 | 10:36 AM
mattbeeezy's Avatar
mattbeeezy
I had this issue with my 2008 LS460(also with an 8-speed transmission). They called its a "Shift Flare", I would take it to Lexus, they had to update something with the ECU I believe. Whatever they did fixed my issue. Also all the newer lexus' have a sealed transmission so I doubt you have a low fluid level unless you're leaking it some where.
Quick Reply: First gear
