Help please. Flat tire sound but no flat.
I hit a curb a couple days ago and now my left side of the car sounds like it has a flat tire. It sounds like it is slapping the road, but all tires are filled to spec. I did took it to the mechanic after the hit.He lifted up and had someone inside pressing the gas pedal while checking for noises. No sound was being produce from the car, but he did noticed that my wheel was bent and it was wobbling. He told me to order a new one and so i did. Today, i went get the new wheel installed and road forced,but the sound is still there. My car is behaving normal, it is not being pulled toward any side. Turning at high speed does not produce any louder noise. Steering wheel has a little vibration. Any of ya possibly know what's going with my car?
When i hit the curb it really messed up the front and rear driver side wheels. I probably hit it at 35 to 40 mph.
Update 1:
I took the car out late last night for a short drive so i can hear the sound better and the sound is still the same coming from front driver side. From what i have been reading up around other car forums, i believe is the wheel bearing. When i veer slightly to the right the sound is more pronounced, and it is coming from the left side front. Anyhow, i will take it to another mechanic and have him look at it again on Monday. Just in case if it is the wheel bearing do you guys have any recommendation as of brand wise? I heard good thing about Koyo and Timken or should i stick with OEM?
Update 1:
Anyone here can only make a wild guess what the problem is. Take it to the dealer's service department or a reputable independent shop.
Besides the bent wheel(s) you could have damaged any number of suspension parts or hub/axle, etc.
Thats my plan for Monday, probably bring it to another shop to get second opinion.
I hit a curb a couple days ago and now my left side of the car sounds like it has a flat tire. Itr is sounds like it is slapping the road, but all tires are filled to spec. I did took it to the mechanic after the hit.He lifted up and had someone inside pressing the gas pedal while checking for noises. No sound was being produce from the car, but he did noticed that my wheel was bent and it was wobbling. He told me to order a new one and so i did. Today, i went get the new wheel installed and road forced,but the sound is still there. My car is behaving normal, it is not being pulled toward any side. Turning at high speed does not produce any louder noise. Steering wheel has a little vibration. Any of ya possibly know what's going with my car?
lserlohn
RX - 1st Gen (1999-2003)
05-09-15 12:32 PM
