I went with RSR DOWNs not super downs
Anything else I need to know? (completely amatuer at this)
So this would be all I needed? http://www.rs-r.com/product/lexus-gs...-springs-2013/
NickMayer (07-26-19)
It's ok were all here to help, and correct that'd be all but since it'll all be apart, you might want to look into upgraded aftermarket shocks and struts too , entirely up to you, but might as well kill two birds with one stone. Otherwise you can always use stock suspension like I did.
Not sure about the GS and "modern" cars. But during the 1990s during the "Honda" days, it was said that the lowered springs caused the shocks to travel at a lower-stroke height which takes it out of its typical operating range. This was what caused the factory shocks to wear out much quicker.
The following 3 users liked this post by azipod:
Much shorter time. Probably 25%-35% of what it should be.... just depends on the car. Given the labor involved, I would swap the shocks when you do the springs. This is the correct way to do it. Aftermarket performance shocks are tuned better for the stiffer lowered spring and it's setup to perform with the lowered stroke. Stock shocks were never meant to be used with lowered springs and they wouldn't perform correctly even if they were new. One issue you might have is having your car bottom out during bumps especially when you car is loaded with a few people. Stock shocks are too soft for lowered springs.
Going to need to nail down specifics so I can price that out I guess... So much to do..... Anyone got 20k I can borrow?
-Mike
I’m older so I have been modifying vehicles for a long time. Typically when you change the springs you’re changing struts/shocks also. We progress, innovate, & change. So I sent an email to RS-R in regards to this subject. This is the response that I got.
Hello,
Thank you for contacting us.
We recommend keeping the factory shocks/struts as our springs were designed to be compatible with OEM parts.
Best Regards,
Thao/RS-R USA
Hello,
Best Regards,
Thao/RS-R USA
