2013 Alternator output?
Our 2013 F Sport was deader than a doornail this morning. Battery read 3.5v. Dead.
Car was CPO a year ago May, with almost 60K miles; came with a new Lexus battery dated 5/18.
Has been perfect; a great car. Love the dang thing.
Pulled and charged the battery for almost 3 hours, 12.2v. Reinstalled and started car. Idled fine.
Turned on lights and read voltage at battery leads; 13.5 volts. Revving did nothing.
I would imagine a car with this many electronics would easily pull 14+ volts, perhaps 14.7.
Your thoughts? What should the alternator output be?
Will probably go back to Putnam Lexus in Redwood City tomorrow.
Kinda scared because they have lotsa nice cars there.. Sheesh.
I was planning on keeping this one for a long time; it sits outside... Sheesh.
8. INSPECT CHARGING CIRCUIT WITHOUT LOAD
(a) Connect a voltmeter and an ammeter to the charging circuit as follows.
Ammeter
*2
Terminal B
*3
Generator
*4
Voltmeter
*5
Battery
(1) Disconnect the wire from terminal B of the generator and connect it to the negative (-) lead of the ammeter.
(2) Connect the ammeter positive (+) lead to terminal B of the generator.
(3) Connect the voltmeter positive (+) lead to the positive (+) terminal of the battery.
(4) Ground the voltmeter negative (-) lead.
(b) Check the charging circuit.
(1) Keep the engine speed at 2000 rpm and check the readings on the ammeter and voltmeter.
Condition
Specified Condition
Terminal B - Body ground
10 A or less
13.2 to 14.8 V
Text in Illustration
*1Ammeter
*2
Terminal B
*3
Generator
*4
Voltmeter
*5
Battery
Standard Voltage
Tester ConnectionCondition
Specified Condition
10 A or less
13.2 to 14.8 V
Boomin (07-28-19)
Mine is anywhere between 13.5-14.2 while driving, so I think your reading is quite normal.
How many days did you leave it sitting before the battery went dead? It's good to use a smart battery charger to top up your battery once in awhile, especially if you drive short distances. I recommend CTek chargers.
Last drove Friday afternoon. Dead Sunday morning.
Wanted to get the Model 3 out of the garage this morning around 8:30. Nope.
Kinda strange... My uneducated guess is a dead cell in the 1 year old battery.
I believe a size 34 fits?
Please advise and thanks!
If it's only been 1 yr, you should still have warranty on the battery.
2ya
08-02-06 04:50 PM
