How is your no drill spoiler holding up with tape only?
Old 08-18-19, 04:24 AM
mkmckinley
mkmckinley's Avatar
If you ever need body/paint work Haury's Lake City Collision is excellent.
Old 08-19-19, 07:50 AM
ULTiMaX99
ULTiMaX99's Avatar
Originally Posted by NickMayer
Before installation, when they *assured* me if would go on fine if I used a heat gun. The aftermath which is after a month or 2....
Something similar was happening to my rear spoiler, except it was popping up in the middle. If I pressed on it, it would stay down, but when it got warm, it would pop back up. I had to double or triple stack the double sided tape in the area it was popping up and used the 3m adhesive promoter/primer. It's on there good now and no lifting even when it's hot out.
Old 08-19-19, 11:21 AM
bclexus
bclexus's Avatar
Received 2,250 Likes on 1,604 Posts
I've had ground effect body pieces remain solidly in place at over 150 mph using proper 3M automotive tape. Unless you have a heavy piece or a large captive area body piece that is subject to strong vertical aerodynamic downforce (e.g. sizable front spoiler or rear wing) you should be fine using just the correct tape as long as you prep it and install it correctly by doing it within the right temperature range and letting it cure properly.
mike51O
07-30-11 11:12 PM
dedott21
IS - 1st Gen (2001-2005)
01-16-09 10:57 AM
ReLexin
04-18-07 10:20 PM
knick33
07-04-06 07:02 PM
delmo
GX - 1st Gen (2003-2009)
02-09-04 09:49 AM
Quick Reply: How is your no drill spoiler holding up with tape only?
