Carlinkit Android Auto Apple Carplay for $319
#451
https://www.clublexus.com/forums/gs-...l#post10791824
Update your firmware to the latest version if it's older and that should make the mouse control so much better. Basically left and right are the fastest/best way to navigate through the menu.
#452
I created a post with the latest firmware, go here:
#454
#455
12v rear is outputting 12v only when you put the car in reverse.
You don’t need to connect reverse signal wire because carlinkit already knows when you put the car in reverse and switches over the screen. You just need to select aftermarket camera in Carlinkit settings.
#456
FW in my box is higher than what you have but I went ahead and rolled back to your update. Joystick control was improved but it’s still frustrating to use in CarPlay. I gave up on this CarPlay for my car and decided to return it hopefully they won’t give me a hard time. Those sneaky guys are very quick in responding to my product inquiries but once they got my money took them long to reply. Lesson learn I guess.
#458
#459
what problem are you running into with CarPlay? I got the off and on with no audio but if you turn off the Bluetooth on your phone and turn it back on it works right away. I ordered mine from alibaba and they are quick with the response. My firmware looks nothing like what you guys have.
So I woke up in the middle of the night I just realized joystick was controlling both Lexus menu and CarPlay menu that’s why it was so hard to control. That’s not normal right? I had Lexus radio on when I was using CarPlay and it was changing station by itself I thought it was a bug turns out I was the one changing station. Someone here had same issue is it harness connection problem?
#461
@peasodos
How did get it to work the second time to fix mouse controlling both Lexus and CarPlay? I have the same issue except I don’t have split screen like GS but it’s still controlling Lexus system in the background.
https://www.clublexus.com/forums/gs-...l#post10724675
#462
Hmmm that’s definitely not right, mine on controls the CarPlay. I’m running the split screen wire since I have the 10.25 oem, maybe try switching to the spit screen cable
#464
How did you remove these black connectors they were really tight not sure there was a tab I used pliers to pull them apart but connectors hosing may have broke.
#465
Update on my Audio Issue - I'm having an issue with AUX wherein music is coming out of the right side speakers okay, but on the left side, I can hear it, but it's very very faint. I tired adjusting balancer etc - no luck.
Today, I took an old Ipod and hooked it up to AUX in the center console and the same issue is present using the iPod in AUX - music much louder on right side speakers. Which leads me to assume this is a hardware issue with my radio and not with Carlinkit - which is a huge bummer for me and using this now.
Any chance this would be covered under warranty?
