Carlinkit Android Auto Apple Carplay for $319
#542
My aux isn't populated however...
#543
do you also have 9.2.9? As the poster mentioned above?? Not sure what his MCU version is..
#545
Here is the latest MCU Version (20.11.4.14):
https://drive.google.com/file/d/1WPW...ew?usp=sharing
Extract the .BIN FILE to your USB after you've formatted it to FAT32 with default settings.
Plug USB into USB port of Carlinkit.
Go to settings -> update -> 4091 -> MCU Update -> confirm
The following 5 users liked this post by IntrinoX:
byungkuk (11-06-20),
DeneAlex (11-07-20),
ericsan13 (12-13-20),
Measured (11-09-20),
Voronmetro (11-22-20)
#546
Here is the latest Software Version (9.2.9):
https://drive.google.com/file/d/1QcM...ew?usp=sharing
Go to settings -> update -> 4091 -> software Update -> confirm
The following 4 users liked this post by IntrinoX:
#547
Yeah for just standalone wireless carplay it works great. I also found out it works much better with iPhone 11 Pro than with my old iPhone X. Also much better for CarPlay than Android Auto. As far as address input go I just do that on my phone and I don't use siri, but probably should.
#548
So I just got this kit in and installed it immediately. It’s pretty disappointing with the joystick.
It seems like it moves the cursor according to what’s on the OEM INTERFACE.
If I’m on the CARLINKIT INTERFACE, it doesn’t allow me to move up and down, only what’s shown on the OEM INTERFACE.
Does anyone else have this issue?
I’m on the menu homepage on my OEM screen, and it sure is moving along with those selections.
Here’s a video of my joystick.
https://imgur.com/a/JXtJXjj
https://www.clublexus.com/forums/gs-...l#post10913776
In my case it didn’t solve my issue I had same problem on my IS350. If not leave the way as is let the joystick control both systems, OEM stereo and CarPlay.
Instead you should install a track pad it works much better. Even if Lexus joystick works in CarPlay it’s pain to navigate with joystick it barely works. The reason I said to leave the way with joystick controlling both so that you can still use Lexus joystick to control oem system. After I swapped the black connectors on my harness I lost the ability to control oem system.
#549
Did you try swapping the black connectors as I showed here post #528?
#550
Update done
thanks itsRaymond! Will have to wait and see how it works out in the next few days
#551
#552
I am thinking of getting and wrapping one of the wires...but which one??
#553
steegro, did you find a fix? I just installed the unit and found the touchpad and steering wheel buttons are not working at all for my 2015 NX300h. Appreciated if you ort anyone could share any insights. Thanks!
#554
Did you follow the instructions for touchpad and the appropriate screen size for NX300h? If you scroll up I reposted the installation instructions that breaks it out...
