Carlinkit Android Auto Apple Carplay for $319
#722
My Carlinkit unit arrived and I got around to installing it this morning. No real issues other than me hooking up the wrong cable that taps the AUX input. Took me a bit to realize what I'd screwed up. Seems to be working well. I'm going to do some more testing before I button everything back up and find a place to store the main unit and extra wires.
I do seem to have a later firmware on mine.
#723
From left to right:
MA Audio Ground Loop Noise Isolator - 0% buzz reduction
BESIGN Ground Loop Noise Isolator - 30% buzz reduction
Kript HiFi Ground Loop Isolator - 32% buzz reduction
PAC SNI-1/3.5 3.5-mm Ground Loop Noise Isolator - 40% buzz reduction
100% subjective testing. I tested by increasing volume to 60 and plugging into the AUX port in the mid console. I have the ML system if that helps. I'm keeping the PAC SNI-1.
#724
From left to right:
#725
#726
I had no audio before I rewired the cable and after audio works with no static, so not sure how helpful that is.
#727
https://www.clublexus.com/forums/gs-...l#post10991867
Carlinkit uses 1 to 4 below so you cannot splice in the ground loop isolator without known which pins to tap. Not an easy project.
#728
Looks like we chatted about it back in Feb
The beatsonic cable (minus video) looks like the 1-3 one. I thought rewiring meant - re-addressing the pins into the plug adapter. Another alternative could be shielding the wires up tighter. Could the antenna also cause an issue? I put mine on top of the radio unit which seems like it would be fairly close to the harness cables... Maybe i need to re-position the adapter somewhere else.
#729
Just a note for those with the older-gen system, this kit (or its Aliexpress clones) will work. I have a 2013 GS with the 12in screen and successfully got it all working (split screen, good res) but it has 2 faults which I hope to solve, when going from the Carplay interface back to the original car it works, but if you want to get back into carplay it doesnt do it until the car re-starts. This could be the box or my phone (which is old, iPhone 6). The 2nd issue is the joy stick...its hard to use but with wireless carplay just do what you need to do on your phone and that problem is solved. Need to punch in a destination, just use the phone as the keypad and it'll pop up on the screen.
The item I bought was from a seller named Kolom on Aliexpress.
Once i get it figured out, I'll post details.
#731
#732
Hi all, new registrant but had been reading / lurking on the net and forums for the last week. I have a 2015 GS 350 with F-sport. Was interested in exploring the option to get carplay and narrowed down to carlink and roadtop...both seem to be just resellers of the same unit ...seems like just a rebadged from the same manufacturer. I am an iphone user so only care about carplay. Had some questions and would greatly appreciate your input/ help. carlink seems to have better support communication (whats app) but found both of them to be responsive on aliexpress chat. Roadtop has a ebay store so hoping to buy it from there just in case if i have to deal with returns.
1) Installation: I have seen the beatsonic video on GS and feel comfortable to try it on my own but if there are other videos that help, i would greatly appreciate sharing it. Any pics on where you put the unit...i have read that some put in the glove box or near the transmission area etc. but wasn't very clear on it
2) wiring instructions: Anything that i need to be aware off....got the roadtop manual yesterday night...not sure how updated it is or not. Also read a bit about the DIP switches etc
Best
Best
#733
there is another seller on Aliexpress that is selling a similar unit for lot less than Carlink or Roadtop but seems very similar. Got this from the posts few pages back
https://www.aliexpress.com/item/1005...c003e2rME&mp=1
Is the cost difference just the DHL shipping, which can be 60-80 usd vs the subsidized china mail. I would guess that Carlink and or Roadtop to be lot more accessible for support if needed
@DavidL you probably bought this, any input/ experiences. Thanks
#734
#735
I no longer having buzzing on my carlinkit unit... I did tinker with the audio setting a little bit (don't remember what exactly) and also updated my iPhone to iOS 14.8 then to iOS 15. YMMV
