Carlinkit Android Auto Apple Carplay for $319
#811
#812
Can someone post a link to the carlinkit? I tried to google it, but only came across this: https://carlinkitcarplay.com/ which is for systems that already have carplay on it. I tried to go through the posts but there have been so many links over the past couple of years and a lot of the ebay links are no longer available. Btw, I am running a 2015 F-Sport. Are there still any outstanding issues? I am not looking to upgrade to the 2016+ screen.
#813
#814
AACarPlay enables Wireless CarPlay and Android auto
We are here to assist with any infotainment system questions or issues, generally, anything CarPlay or Android auto-related so let us know how We can help.
We've updated the adapters to the latest Android 11 OS, which works more stable and gives a faster transmission.
2022 Premier Adapter
All car adapters at AACarPlay
- Wireless CarPlay
- Wireless Android Auto
- AirPlay/ Chromecast Video streaming media to car screen
- More.
- Wireless CarPlay
- Install any apps to your car screen (YouTube, Netflix, Games...)
- More.
#815
- Wireless CarPlay
- More.
- Wireless CarPlay
- More.
peteharvey (07-04-22)
#818
Also, if you don’t have sound coming from Carplay you will need to connect Audio-GND coming from the main harness. You can either use the GND cable from the usb/video harness or ground directly to the chassis.
#819
Hi there.
i just install roadtop cause carlinkit out of stock in my region. Install was easy then i thought. I watch more then 3 times on youtube and read this thread from begin to now. The roadtop work well on my gs 300h 2016 with 12.3 inch non ML.
but today i saw problem with back up cam normal lexus parking assit show little car with rear and front yellow red distance at the right now is gone.
Can someone with roadtop unit post your settings in the revert menu?
Thank you to much
before must like this
Thank you to much
#820
#821
#822
thank you for explain. It really show up when i come to closing obj. But the orginal always show up when i put in R. Have you the same roadtop?
#823
I've been having connection issues for a while.. and changing the wifi channel to <6> made it tolerable but once I went to using it in wired mode - i've had zero issues. Everything is snappy and connection has been understandably solid.
Now I think the issue is with the antenna. I stuck it to the top of the oem radio unit and that's probably the culprit (metal on metal). I've also thought about upgrading the antenna to a higher powered one as well (people using GROM have done this). For the antenna, where have you guys placed it? Maybe if I can just move it to somewhere else - it might help with the issue..?
#824
#825
