Carlinkit Android Auto Apple Carplay for $319
#871
#872
https://www.clublexus.com/forums/gs-...15-2019-a.html
#873
The $300 =/- Carlinkit is the best deal going. It's also sold on Amazon too. Some of those others are just re-cloned marked up price kits. $1000 for it is just a ripoff imo.
Astrokat (06-23-24)
#874
I have ES300h 2013 and installed Carlinkkit. Do you know if I can run or connect usb and AUX connector from Carplay kit to the USB and AUX ports inside the armrest by hiding them under the console panel? I don’t want them expose. Thank you
#875
Car won't start after install😬
BUMP
I installed a RoadTop airplay module on my '14 with ML system. I disconnected the neg during install. At first the unit worked ok, then randomly, after a few more minutes eventually stopped working. I tried starting the car but it won't turn, I just hear rattling noises like you hear when you accidentally press START while the engine is idling. I decided to uninstall the module and re-install the OEM unit.. Still the car won't start, 2/3 of the screen is blank, warnings on the dash flashing, and I'm getting a prompt to see dealer.
Do I need to get the battery jumped? Is my ML stereo also now damaged? Please help. TIA.
#876
BUMP
Problem solved. Recharging battery did the trick. I'm probably not going to install the aftermarket RoadTop Carplay module since the unit is too glitchy..
Note to self: expect having to recharge battery whenever working on something electronic with these vehicles.
