DIY brake job
Plus I don't really know when is the right time to change the rotors, no one has provided a scientific measure like the minimum thickness.
I'm almost 100k miles on oem rotors and no significant lip on the rotors, zero issues with the brakes.
This is a rotor that should be replaced, see the lip on it: If the thickness of the rotor is still in spec, some shops will just grind the lip off the rotor. I would ask the dealer for their rotor thickness threshold, but at your low miles this should not be an issue at all.
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/1024x683/5709026173_ea29cb8c6b_b_c19f173cb206f77d5f7013ca55d86a7a3e343ec8.jpg)
I have a 2015 GS350 non-f sport too. Replacing the front brake pads is SUPER easy. Takes more time to jack up the car and take off the tire than it does to change the pads. google a youtube video on it. There is a long rod held in place with a pin. Pull the pin, tap out the rod, remove a metal bracket, remove the pads, put the shims from the old pads to the new ones (put a little anti-squeal gel between them), push back the calipers (I used a C clamp, but pliers would work too), put in the new pads and reverse the uninstall.
I replaced my pads with OEM even though they only lasted 38,000 miles. Didn't want the potential hassle of squeals. Did not turn or replace the rotor...no need to.
I have pads to replace the back set, but they don't need it yet.
I did go with OEM rotors, and I have no clue where the 400 number someone quoted came from, though maybe it is more expensive for F sport? Dunno. I paid 140 (total) for front rotors.
I replaced mine at 68k, though I only had car 20k miles at the time. Pads were new when I got the car, though it had been sitting for a year. No clue if that contributed. I will say, my rotors were warped *bad*. Like seizure level every time I braked going over 35. But that always happens to me, so I get it's my driving and not a judgement on the car, lol
I had and still have the slight squeal in the morning on occasion but it's gone after one or two applications of the brake. It's gone before I'm at the end of my street I live on. If it's a constant squeal you need to ditch those pads.
I am opposite of everyone else here and didn't go with OEM parts. It was way cheaper and they feel much better. I have the powerstop Z23 kit with drilled rotor and ceramic pads. It was $285 for everything when I got it on Amazon. It's now $400 which to me is still a good deal. You're paying $100 a corner basically for a rotor and a pad set. I replaced the OEM stuff at 98k because the rotor were getting warped. I have put about 11k miles on them since and if it needs them again I will certainly replace them with the same thing.
Also just because you're putting on factory items isn't going to guarantee it's not going to do the same exact thing. If you wash your car in the rotor rusts in that mean time it's going to squeal until the rust is knocked off. Happens just about every time I wash mine. Everyone is entitled to do whatever they want obviously I'm just giving you a heads up more money doesn't always mean better results.
It's usually gone before I hit the street and it's only when I apply the brake it's not happening as it's rolling. So I pump the brakes maybe two or three times and it's gone.
