Flashing third brake light help
10th Gear
Sos.. just got my ‘14 GS and was driving it at night for the first time and noticed it has the embarrassing flashing third brake light. Flashes 5 times then stays on. My neighbor has exact same car and hers does not do it. Whenever I see them on other cars I cringe a little. Does anyone know how/if this can be switched off??
Probably had a "Pulse" type product installed by the dealer.
https://www.pulseprotects.com/
I assume you'd need to locate it and remove it. I believe it's usually installed near the brake light.
Lan1 (11-18-19)
10th Gear
You were right!! Took me about 3 minutes. Popped up the third brake light out of the rear deck and there it was. I just unplugged one of the wires and now it stays steady. THANK YOU!!
This had me wondering about dealer installed options.. I found this little part for $4.95 on eBay. Checked the dealer website and sure enough - flashing third brake light is a option that they can install for “only” $995.
Yeah I don't like it either.
10th Gear
I got it off lease from an 70 yr old woman. It’s unbelievably clean. I don’t think she did it herself, if she did.. major props. The red leather looks newer than some of the ‘19s I saw on the lot. She never even took the protective plastic film off the “Lexus” door sills.
I assume she was talked up by my dealer to install it as a “good safety feature.” Doesn't surprise me that she forked over the cash either.
Enjoy and be safe!
10th Gear
My dealer installs these on all of their inventory and charges $295 for it. I have always refused to pay that and they’ve dismissed the cost. I still have to remove it from my 19.
I've seen this "Strobe" type brake light on third-eye brake lights and standard brake lights as well - its actually distracting IMO...it feels more at home on an emergency vehicle or school bus with flashing lights.
Locally, seen it on a lot of riced-out Honda's that are begging for additional attention.
10th Gear
10th Gear
I have noticed my center brake light does that, flashes quickly several times, seems to do it when lightly applying the brake. Not sure why it does that, thought it might be standard.
So a dealership installs those things and they can be disabled?
10th Gear
Yup! Learned a lot tonight. Dealership or owner installed. Can be disabled easily depending on where the module is. Mine was located under the 3rd brake light housing which is super easy to remove, it just pops right out of the rear deck. I found a little rectangular cube which is the flasher. Then I unplugged the cable that was clipped into the original wiring (I’m assuming that’s the power draw for the flasher module) and it now stays steady when I press the brake. No more flashing!
shabbyblue
09-14-14 01:39 AM
