Tire Chains for Snow Driving in RWD GS
There's a pretty major difference here in tires. OP can clarify, but I bet he's running on summer tires. I would have no issue running a RWD in the snow with snow tires or a good set of all seasons, but I would not do it with summer tires. Unless signdetres swapped out tires, his RWD F Sport came with summer tires.
From experience, summer tires in any amount of snow will end in disaster
RWD with a set of snow tires
RWD with A/S tires is fine as long as you drive cautiously and smart
I've driven in snow with the GS 450h on all season and also a GS 430 with summer tires. The hybrid has a battery pack that helps create weight in the rear so thats the benefit and some good all season or winter tires. The 430 was useless couldn't really get anywhere not even up a gas station incline was stuck so I would def get some snow chains if you plan to use your car, the stability control should be able to really help you. You can drive a RWD car in snow just need either the tires or chains, and you would need four as you have summer tires.
Im2bz2p345 (11-24-19)
The following 2 users liked this post by peasodos:
Im2bz2p345 (11-24-19),
signdetres (11-22-19)
Just the fact that the chains are mounted with straps rubbing against the wheels would be a no go for me. As clean as your GS is, I don't think you'd want to scratch your wheels with any traction device. Rent something and be done with it.
ItzFilyO (11-23-19)
Thank you, everyone, for all the info & advice. Doesn't seem worth the risk taking the GS, with or without tires chains, at this point & I definitely don't want to drive in the snow on summer tires. Most likely I'll end up taking my mom's QX50 instead.
The following 2 users liked this post by signdetres:
ItzFilyO (11-23-19)
ItzFilyO (11-23-19)
