Night mode for navi maps
I recently purchased a 2016 Lexus GS and it's been great after a few minor issues. However, I noticed that the navigation maps are super bright at night. Is there a night mode for that? If so, can this be setup to auto detect?
Thanks.
Thanks.
The Day Mode setting seems to be intended to provide the bright daytime illumination when the exterior lights are on,
perhaps while driving in a funeral procession or just daytime rain.
The oddity is that the "Day Mode" setting is only shown on the screen...at night! Cover the headlight sensor on the
dash (the quarter sized black dome) with your cellphone or other opaque object and turn off the "Day Mode".
Try this:
Using your DISP button (on the steering wheel) see if you have the option of switching it to go back to Night Mode. I think turning Off Day Mode (or selecting Night Mode) will automatically make the default go back to default Night Mode, which will auto-dim your NAV screen when the sensor detects low light level.
FYI - If I'm not mistaken, to achieve full time Day Mode (which is what you say you have now) actually requires that the car be fully in the dark with all sensors (headlights, mirrors & NAV screen) sensing darkness. Then, and only then, will you have the Night Mode option be triggered and made available on your DISP to change it to Day Mode (which is what you have now and want to get rid of). This Day Mode option (using DISP button that you have now) will likely not be available during the day because all sensors must be in the dark to trigger the option's availability.
I hope this helps!
Please let us know if this allowed you to change it...
websurfer - I suspect someone has selected Day Mode as default, which prevents the NAV screen from auto-dimming when the sensor detects a low light level. (For some reason Lexus did not cover its operation nor how to change its operation in the Owners Manuals.)
Try this:
I hope this helps!
Try this:
I hope this helps!
I've been trying to figure it out for a few weeks and yes, the manuals were no help. Googling didn't help on this also.
The OP should be able to change it from Day Mode using the DISP button with the instructions I provided.
Many vehicles, including Toyota, require that the instrument cluster lighting be at least one notch below full brightness for the Night Mode work when the headlights are turned On. The GS 350 Lexus does not work that way.
You added the image after I replied so I was unable to see it. I'm pretty sure that my GS 350's NAV auto-dimming is not altered/changed by the instrument panel light control like I realize some vehicles are. Maybe Lexus changed the GS 350 after my model year. I know that I have my instrument lights at full brightness, yet my NAV screen dims in low light and darkness.
I have my instruments on full bright but my nav day mode still works.
Hopefully we can get it fixed for websurfer.
CAKETOWN - The Owners Manual image you posted is only for the automatic adjustment of the instrument panel lighting. It has no bearing on whether the NAV screen auto-dims.
Here is an image of the Owners Manual page that shows more information:
