An update - a new clock spring fixed the squeaking noise. You don't have to buy it with the steering sensor, that's expensive, just buy it alone. Success!
Out of curiosity, what is the part number you replaced?
I had the same issue on my RX, except it was WAY worse than these videos. The issue was the backing plate, not the clock spring itself which I had thought was the culprit. They re-adjusted the backing plate and the sound went away.
