Battery replacement
#61
Last year I bought this battery for my 2011 GS350 to replace the original battery.
https://www.batteriesplus.com/produc...cca/sli24agmdp
Here are the specs:
Type: Standard
Here are the specs:
Type: Standard
- 60 Month Free Replacement Warranty
- Pure lead technology delivers the performance of 2 batteries in 1: starting and deep cycle
- 28X more vibration resistant than conventional batteries
- 100% spill-proof and maintenance free AGM technology
- 2011 Lexus GS350 V6 3.5L 585CCA Car and Truck battery
#64
Here are the specs:
Type: Standard
Here are the specs:
Type: Standard
#65
I bought a Bosch AGM battery 4 year replacement warranty. Which I had to do, Pep Boys gave me one that had been on the shelf for to long. They gave me a new one no questions asked.
I read in this forum the original Lexus made in Japan batteries are not available in the USA. Mine lasted 8 years. Now you guys are saying that info was wrong. If you can get the original for a reasonable price that is the way to go
#66
^^^^I had a Bosch AGM Battery in my ISF. I saw my old car last month at a Lexus "F" meet last month. It still has the Bosch AGM battery - Six years old and still going strong. And that's in the brutal summers in Southern Arizona, a climate that is hard on batteries. My OEM Lexus battery lasted 4 years.
The NAPA AGM battery (Bosch didn't have an AGM in the correct size) in my truck, also six years old is still in reliable service.
Whenever I buy a battery, I check the date. If, IMO, it's too old I reject it.
Lou
Lou
imjohnphan (01-29-20)
#68
#69
dont do it. Get a lexus battery. I changed mine everything matched Amps And was recommended by Autozone. Clock ran fast 20 mins everyday. Swapped clock it ran slow 20 mins. Clock worked perfect until I put in the aftermarket battery. I promised to sell the car over a clock if lexus did not make it right. “I Sold the 2014 Gs350 last week”.this is a true story...
I went aftermarket since the original 450h battery from the dealership is $450, not only that I up-sized the battery, and modified the battery tray to fit. It doesn't matter what 12v battery you install as long as it has at minimum the same CCA and fit's the battery tray.
#71
![](https://i.ibb.co/Wf919BZ/slap-smiley.gif)
#72
Haven't read thru all this thread but, is anyone here using a memory saver when they change their GS battery? Mine is 5 years old and lives 99% of its life on a Battery Tender. I figure I'll replace it next spring and do it myself just because the dealers are too careless with my cars.
#73
Then, in the ignition ON position, give it a few minutes to boot up after that before starting the engine. I am willing to bet that most issues related to battery changes are as a result of disconnecting too quickly or starting up and driving without letting everything reset after a battery change.
#74
My 2013 Panasonic battery gave up this week. I am not certain if it was the original battery or replaced sometime prior to my purchase in 2017.
Typical failure: first really cold morning after weeks of sitting idle: no crank, only clicks. I put my battery charger on it overnight, and it complained that the battery was bad. I disconnected and reconnected it, and it eventually said it was charged. I ran an errand, and it started with a notably slower crank. All symptoms of a battery in need of replacing.
I bought the rebranded Interstate battery from the dealer.
00544-MF240-575 for $172 net of core for the old battery.
Comes w 84-month warranty.
I turned the car on without starting it and watched the system do its preloading w the progress bar, waited until everything was on, and then started.
All is well.
All is well.
#75
I did for my battery swap but I also had disconnected the battery for a steering wheel swap and could not use a memory saver. I had no issues for both procedures. Either way, make sure to let the car sit off for at least 10 minutes before disconnecting the battery and the same before turning on the ignition switch once the battery is reconnected.
I do recall that on the first time trying to start the car after installing the battery that mine will crank for a second or two and then stop. When I first encountered this I thought something was broken but with a second push of the button it started up. This has happened every time. I'm not sure why it does it but it scared me a couple of times.
praetor
09-10-16 10:52 AM
