Finally found correct paint to fix scratches on the rims.
Old 01-30-20, 01:46 PM
  #31
arosnes
arosnes's Avatar
OK, so since there is nobody that can fix this I am investigating further. The paint from amazon is a bit too bright.
In general, spot fix should be same or darker color tone. So I went back to the can of paint that my car paint specialist blended for me
based on the scanner. It was way too dark when sprayed normally (pic in first post)
So i put on a very thin and dry coat with a brush and it looks better. I will try to put a second light coat on top of the clearcoat after
I polish (rather wetsand) the clearcoat. The clearcoat really fills well and polish nicely.
Old 01-30-20, 02:09 PM
  #32
bclexus
bclexus's Avatar
Received 2,176 Likes on 1,559 Posts
This video may help you. The painting starts at 17:00 into the video.
Old 02-06-20, 12:34 PM
  #33
arosnes
arosnes's Avatar
So to sum up. I ended up with putting a light coat of medium silver over my first coat of custom computer scanned paint, that seems to make the best match.
From some angles it still looks horrible...
I am starting to think that maybe a non-metallic grey will work better...
Old 02-06-20, 12:38 PM
  #34
peasodos
peasodos's Avatar
Received 2,229 Likes on 1,450 Posts
Still looks like poop.
Old 02-06-20, 12:46 PM
  #35
arosnes
arosnes's Avatar
Rim number 2 had curb rash, I generally like the result a bit better in this case, don't know why. I filled the scratches with bondo/filler, painted one coat black, sanded with 4000 pad, painted two coats of custom code paint and one light coat of medium silver over that.
At least it does not go all black from some angles like the other rim.
Old 02-06-20, 01:07 PM
  #36
arosnes
arosnes's Avatar
I concur...
Old 02-06-20, 07:08 PM
  #37
arosnes
arosnes's Avatar
This guy has done some serious experiments:
Old 02-06-20, 07:23 PM
  #38
JDR76
JDR76's Avatar
Received 1,615 Likes on 1,030 Posts
The results may not be what you wanted, but good job in trying! I’ve enjoyed following this thread.
Old 02-06-20, 07:26 PM
  #39
bclexus
bclexus's Avatar
If you have a hobby shop store nearby, you need to visit them. They should have a good selection of chrome paints.
Old 02-08-20, 04:48 AM
  #40
arosnes
arosnes's Avatar
Thanks for the comments. I am currently investigating ideas involving using stickers and vinyl wrap with crome effect.
Old 02-08-20, 08:33 AM
  #41
bclexus
bclexus's Avatar
What! You're kidding, right? Chrome effect stickers on your wheels! How 'bout some playing cards for the spokes?
Old 02-08-20, 08:36 AM
  #42
peasodos
peasodos's Avatar
So you gave up using paint and now resorting to stickers? Does that mean your going to go back to paint if the sticker fails?
Old 02-08-20, 10:35 AM
  #43
UDel
UDel's Avatar
You need to start over and sand your finish down so it is perfectly smooth, no bumps or ridges, any part that is not totally smooth is going to stand out more when you apply paint/clear, you will likely have to add some filler/bondo to fill in the ridges of the scrapes and sand it to get the smooth finish. Then you have to spray it on along with some 2K clear to get anything resembling a decent finish. You should be using urethane paints. Paint is not going to fill in any ridges that you can see or feel with your fingers.
Old 02-08-20, 12:24 PM
  #44
arosnes
arosnes's Avatar
Thanks for the creative suggestions The goal is only to find something that is slightly better than the black spots while standing close to the car.
Something like this...
Old 02-08-20, 12:53 PM
  #45
arosnes
arosnes's Avatar
Chrome paints are tricky, they fail if you coat them with clearcoat. I did order the one featured above but that will take weeks to ship to Norway.
But your suggestion made me go thru the archive of RC model iron on shrink wrap coating and I found this:
Quick Reply: Finally found correct paint to fix scratches on the rims.
