Changed my foglights to LED. Detailed photos of the process
As noted in the "What did you do to your GS today" thread, I installed the first out of two brand new Miromoto LED foglights last weekend.
This weekend I did the other one in less than half the time while taking photos of everything.
There is no quick way to do this; the wheel must come off, many screws and some clips must come off, and you must crawl head first under the bumper with the car jacked up and secured.
But it is not difficult, just fun.
Remove 4 screws Twist and pop out pins from two clips on the edge and pull apart
When I did mine I just turned the wheel all the way to the inward position.
Removed the two side bumper clips, and the couple bolts underneath(only had to feel with my hand, since I knew were they were, taken bumper off before).
This allowed me to bend the plastic fender liner out of the way enough to stick my hand inside. Then there is only one screw holding the fog light in place.
Guess that is possible. Which brand lights was this? As you will see there were some steps that made me glad to make the access as good as possible.
Miromoto warns that a minor modification is necessary. The mounting tabs on the side without the one screw, are a bit too long and must be cut Close up of the problem After cuting the tabs the light center properly Bad lighting, but the tabs are cut in this photo
In order to be fully happy I cut the little plastic pin that support the fourth mounting tab. Without doint this the frame would twist when I screwed the light to the frame.
Yea, I swapped out my OEM foglights to the Morimoto LEDS without a jack, only turning the wheel to the opposite side.
Took the wheel well clips off, undid the screws underneath the bumper, then ratcheted the single screw that holds it in.
Took 5 minutes per side
Did you have any info on how to assemble the electrical plug? I did not have any info on that so I had to test the polarty after assembly. And doing that with only the access after removing the clips would be harder
Just look at the existing plug on the oem fog light, black is ground, so just push those pins in the socket so they connect the same way.
