Transmission stuck in one of the gears and not shifting
#46
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/640x480/w01332111651oes_6cd084ac73e28a68388a56095f48626c353caee5.jpg)
jonathancl (01-31-20)
#48
Which gives an indication as to what their markup is. You do the math, online merchants sell the entire thing for $7K and they'd be making money. Say they're charging 1K for labour, that would mean they're making at least 7K in pure gross profit!
#50
#52
#53
Car is done. Will pick it up tomorrow and let you all know what the records say.
If it wasn't for the warranty, I would have taken it to an independent Lexus/Toyota specialist shop.
#54
We'll never know but, I think an independent Lexus/Toyota specialist shop could have made the repair with a new shift solenoid replacement for ~$500.
Hopefully it will be just like new.
#55
Picked up my car and it drives like normal again. Although when shifting it into paddle shift mode, it's difficult to do so - will bring back to have them adjust.
The paperwork didn't have a lot of information as far as what the cost would have been without warranty. The only thing worth while was the service tech notes which states the issue:
P0071, P0796, P0985, P2714 stored due to excessive clutch clearance causing valve body to clog with debris. Internal Failure in transmission assy.
#56
Code P0796 is the Pressure Control Solenoid - Most likely this code was thrown because the Shift Solenoid Valve SR failed which threw Code P0985. Code P2714 was also thrown because it detected a problem with the Transmission Pressure Control Solenoid.
► Code P0985 is the Shift Solenoid Valve SR - Faulty valve which was the root cause of the transmission problem
Code P2714 was thrown because the Powertrain Control Module (PCM) detected a problem with the Transmission Pressure Control Solenoid
The Shift Solenoid Valve SR is #1 in the image below with the green plug. Part # is: 35240-50090 Cost: ~$200 Labor to replace: ~1.5 hours maximum
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/564x726/screen_shot_2018_03_05_at_2_00_57_pm_5166f0b13ceb12766085f73c2302d10846f0659f_69356b91501dbb3450e6f791aa788244b4bcb611.png)
Do you have any idea whether the dealer replaced your transmission with another transmission or repaired (replaced the defective part) in your OE transmission?
#57
HERE is a 4th Gen LS owner that replaced the Shift Solenoid Valve SR part in his 2007 LS 460L with 193k miles.
jonathancl (02-03-20)
#60
@bclexus Paperwork states they replaced the entire transmission.
gth181a (02-01-20)
