Transmission stuck in one of the gears and not shifting
2014 GS F Sport with 53k miles.
Seeing if anyone has had this issue and what the cause may be before I have it towed to dealer tomorrow. Car starts fine and I'm able to put the car into drive. No check engine lights, etc.
The transmission feels like it's slipping (press gas, engine revs, but there is a delay before transmission engages and car moves), and when it does start to move, it stays in that one gear. It feels like it's starting in the 3rd or 4th gear because when I got home from work today, I stopped on my very slight incline drive way, and it had a very difficult time engaging in the gear for me to pull into the garage. Additionally, when I put it into drive, I hear a "clunk" noise. Anyone experience this before?
I'm surprised there was no CEL thrown. This is the first time I've heard of such a problem with the 4GS.
I presume the transmission has not been previously messed with in any way, including changing the ATF? Did this problem suddenly happen with no previous warning or symptoms?
No issues what so ever before and never had any transmission work done on it, including ATF change. It just happened this evening coming home from work. It drove perfectly fine this morning going to work and this past weekend.
Hard to say what the problem is - maybe a failed upshift or downshift solenoid.
Please let us know what they find.
Parrokeete (02-23-22)
Hopefully not the case, but someone could have beat on it the first 17k miles and maybe an issue that's developed over time. If you feel that gears are actually slipping that's not good. The silly part with our car is you can't easily check the fluid level, I think you need tech stream or a scan tool to do it. Is you car still under warranty?
AaAaa
Unfortunately Techstream isn't of much use, apart from monitoring the temperature.
Did you change the oil recently? Maybe you drained the transmission fluid in error? Don't laugh, it's happened before...
praetor (01-28-20)
Does this only happen when the car is warm or does it happen on cold starts also? I had this happen once on my old old 1991 Camry. Car would drive fine until it warmed up, then the transmission would start slipping. To make a long story short, all it needed was a new ATF oil filter. May not be related to your issue though.
Just went out to test it around the neighborhood.... it can shift into reverse and drive fine, but it's definitely stuck in one of the gears (maybe 3rd or 4th) and doesn't shift. The CEL just came on as well. Getting it towed to dealer later.
jonathancl (01-28-20)
I'm very sorry to hear this has happened to you, but hopefully this can be a learning opportunity for our community.
As someone who is at 102k and plans to go more than double that, I'd love to know more about our transmissions and their weak points
