Sealing cut fenders
If you cut through the factory paint and coating it will eventually rust no matter what you paint it with.
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/800x534/gardoflex_galvanising_bath_kms_jpeg_f002b45f6aa5d12c1c52f41cb6f5189e3a2b60d5.jpg)
Yeah, I plan on cleaning the metal properly prior to sealing it again. "It eventually rust no matter what you paint it with" is a bit strong of a statement though.
I live in CA so I prob don't have to worry much, but I was wondering what you guys in the wetter areas use? It wouldn't hurt me to be safer than sorry. Plus it'd be good reference for anyone doing a forum search later on.
You're not going to be able to re-plate the part and you can't get the same adhesion that the factory paint job achieved. The factory finish starts with plating/galvanization and then goes to seamless heat cured paint that covers the whole surface. It doesn't matter how careful you are cleaning the bare metal. Whatever room temperature curing paint you use will have microscopic pores and cracks that will allow the base metal to be exposed to oxygen. You'll also always have an overlap between whatever paint you put on and the factory paint. This is true especially in the area you're describing where there's a lot of flexing, heat cycling, impact from road grit, vibration etc. Eventually you're gonna have rust.
It's your car, I genuinely do not care what you do with it. I was just trying to answer your original question.
