19" vs. 20" rims - difference clearing the caliper?
I am wondering if a 20" is selected over a 19" due to caliper issues. Can anyone tell me if the 20" is selected over a 19" due caliper clearance issues or is this not an issue at all?
Thanks
G
Thanks
G
The size of your wheel wont matter at all in terms of caliper clearance. It’s your wheel offset and disk type that matters. FWIW I have Work 20”x9+32 Atype front wheels and they clear the caliper with room to spare.
I don't know if manufacturers other than Work use a "disk type" designation. For gdog5149, Work wheels has a specification for the inside of the wheel where the caliper is to account for larger aftermarket calipers.
https://www.work-wheels.co.jp/en/search/guide/
Click "About Disk"
Unless you buy Work wheels, you'll probably only need to worry about offset, but you should talk to someone at the wheel company regarding caliper clearance, especially if you drive an F-sport with the larger caliper.
Click "About Disk"
gdog5149 (02-12-20)
Click "About Disk"
Click "About Disk"
gdog5149 (02-12-20)
jpcdmd
Wheels, Tires & Brakes Forum
04-18-05 11:28 AM
