DIY front seat disassembly to access fan?
My new to me 2013 GS 350 Fsport has a very annoying high pitched two-tone oscillating noise - like a faint alarm - that can only be heard with my head in the driving position, sitting in the seat. Lean my head forward a foot and noise goes away. Lean my head to the right a foot and the noise goes away. Does not change with engine speed or road speed. Drove me nuts for a few days, until I was parked with engine running (and annoying noise going strong), and I chanced to turn off the seat heater. Noise stopped. Heater on highest level, noise resumed. Turned heater down one level, nose quieted a little.
Conclusion: there's a fan in the seat back that runs when the seat heater is on (it's winter, haven't tried the seat cooling, but suspect it's the same fan), and it's developed a slight bearing noise. (Second possibility is the heater itself somehow is making this noise, but that seems unlikely - and the noise is like the noise an alternator starts to make when its bearing is just starting to run dry and wear, except it does not come from the engine compartment and it does not change with engine speed.).
In either case, remedy will be to disassemble seat back to access the fan (or maybe heater unit). If the fan is noisy, I'll try to lube the fan bearing. If that doesn't quiet it, then new fan.
If anyone has had the seat apart to access the fan, please post instructions and tips.
Thanks
Thanks
Just so you are aware - looking further into the seat fans, there are two fans (aka blowers) - one is called a 'Seat Climate Control Blower' (for the car seat area) and the other is called a 'Seatback Climate Control Blower' (for the seatback). The information details the driver's seat blowers using 'LH' for left hand. Therefore, I presume the passenger side front seat's blowers would likely be referred to as 'RH', thus giving the impression the blowers for the two front seats are different (e.g. air supply duct connection and mounting orientation, etc.) for the driver's seat and the passenger seat.
The good news is there are only two fans on the seat, both can be removed with the seat in the car. I would first unbolt the seat, tilt it back, turn on the seat ventilation to hear if it's coming from the fan under the seat or the blower behind the seat to determine which one is defective. it could just be something stuck in the fan blades for the one under the seat.
The following pics are from the lux seats, but the base seats have the fans in the same location, just looks less of a cyborg.
There are two fans in the seat, one on the bottom and a blower on the lower back of the seat.
To access the bottom fan you just unbolts the seat(4 bolts), and tilt the seat back against the rear seats:
I marked the fan in red below.
To access the blower on the lower back you have to remove the seat back cover. The following picture shows it's location:
To remove the cover on the back of the seats it's two straps you need to unclip under the seat, then you lift the lower flap up, and remove two screws, then it's a couple clips holding the board in place, you can pull that cover off.
I've removed this cover with the seats in the car, for the first time easier if you unbolt the seats to tilt it back and see the straps.
Here is the instructions to remove the back board/cover on the standard seats.
Here is the instructions to remove the lower back board/cover on the lux seats.
The following 2 users liked this post by peasodos:
Im2bz2p345 (02-15-20),
swolh (02-15-20)
Peasodos - thank you! That is super helpful! I'll post to the thread to report how it goes. Where did you get those instructions? Is that from a service manual that I could purchase? I'm a long time DIYer, a little intimidated by what I call the "computer on wheels" aspect of modern cars, but I still want to be able to do as much as possible myself.
On a different matter, how do you add a signature to posts? Hunted around the site and couldn't see where to add one.
As a new member you must first make 30 productive posts and be a member for 30 days before being able to add a signature.
Once you qualify to add a signature: Click on your User Name in the top right-hand portion of the page where it says 'Welcome, your name'. Then click on 'User CP' in the upper left-hand portion of the page. On the left-hand side of the page you'll see 'Your Control Panel' - look down to 'Settings & Options' and you'll see 'Edit Signature'. You can add text and also an image.
Wow, that's a great link!
I ordered a CD service manual on ebay for $65. 2013 2014 2015 LEXUS GS350 GS 350 FACTORY REPAIR SERVICE WORHSHOP MANUAL CD We shall see if it's any good.
What goes wrong on these seats with the ventilation?
I have an '18 F Sport and I was wondering how much air it should be flowing when on max?
Is there a filter somewhere on the fan that needs to be checked and cleaned/replaced on this? I don't see any filters in the pics above on these seats, but I know some of the other models do run filters on the seat ventilation fan inlets.
