Lux Pkg vs F Sport
Old 02-21-20, 01:19 PM
  #31
peasodos
peasodos's Avatar
Received 2,229 Likes on 1,450 Posts
Originally Posted by signdetres
Then it's really strange that they've had incorrect marketing materials over the entire course of this GS generation. I wonder what the true differences are then between the base calipers & the F-Sport ones.
Honestly idk, they look the same to me, maybe just the mounting points are different since the f-sport has a larger rotor.
Since the pads are exactly the same, the contact patch to the rotor is the same, I suspect the only difference is the diameter of the center part of the rotor the pads don't come in contact with.
Maybe the idea is the larger rotor dissipates heat better, and that may be the only advantage the f-sport front brakes has over the non-fsport, but I doubt that makes a difference for steet use, only on a track. Also larger and two piece rotors look more sporty.
Old 02-21-20, 01:29 PM
  #32
jonathancl
jonathancl's Avatar
Hey man, no one wants hot rotors when they stop for groceries.
Old 02-21-20, 02:07 PM
  #33
bclexus
bclexus's Avatar
Received 2,175 Likes on 1,558 Posts
As I have said before about the F-Sport's larger 2-piece rotor (which some people have elected to replace under TSB with a one-piece replacement rotor) - it only makes a difference if the car is driven on the track where repetitive high-speed braking takes place which generates high heat and the likelihood of brake fading. If brakes have the ability to stop the wheel and skid the tires, and heat is not a factor with high-speed repetitive braking, then the larger 2-piece rotors (or one-piece replacement) on the F-Sport are of no value...with the exception of [maybe] physical looks.
Old 02-21-20, 02:37 PM
  #34
bclexus
bclexus's Avatar
I've never looked into the difference in brakes for the GS 350 models...only that the RWD F-Sport uses a larger rotor. The more I look into the brakes for the GS 350 the more I'm convinced that all models use front calipers that take the same brake pads with no difference in the quantity of pistons (four) or in the piston diameter. Maybe the caliper itself is different due to mounting orientation for the RWD F-Sport due to the larger rotor.
The only difference I can discern is in the larger front rotor size of the RWD F-Sport. Does anyone have information that is different?
Old 02-21-20, 02:46 PM
  #35
mrminsky
mrminsky's Avatar
As much as I love my 2015 F Sport, I can not get over the fact that the seats are hard and just not comfortable for long-distance driving. If I had to do it again, I would go with the softer and better leather of the luxury model. I honestly do not even think these cars have the best quality leather if this is even eather at all. I do love the look of the F Sport much much better than the Lux model. However, the more aggressive look of the 16+ models might be the neutralizer since these models look much sportier than the 13-15 models. The 20 to 30-minute test drive was not enough the reveal the obvious. But once you own it, you will be able to tell. Granted, all our bodies are different and perhaps very few even think about it. But once you notice, you will never forget. Once I get past a 45 minute drive, I feel it.
The following 2 users liked this post by mrminsky:
Im2bz2p345 (02-22-20), Zsikd (02-21-20)
Old 02-21-20, 06:31 PM
  #36
bclexus
bclexus's Avatar
For whatever it's worth, this is my finding for the ADVICS (brand name) Original Equipment Lexus Front Brake Calipers:
ADVICS A5L079 Lexus 47750-22460 Front Axle Left Caliper for: LEXUS GS (2011-) _L1_ - 3.5 350 GRL10_, GWL10_ [01.2012 - present]
ADVICS A5R079 Lexus 47730-22460 Front Axle Right Caliper for: LEXUS GS (2011-) _L1_ - 3.5 350 GRL10_, GWL10_ [01.2012 - present]
The above Front Calipers are exactly the same for all five of the following different GS models (Note: VIN numbers are for salvaged vehicles or vehicles currently for sale):
VIN# JTHBE1BL9E5029285 - 2014 Lexus GS 350 F-Sport Pkg RWD
VIN# JTHCE1BL4E5021003 - 2014 Lexus GS 350 F-Sport Pkg AWD
VIN# JTHBE1BL0E5036318 - 2014 Lexus GS 350 Premium Pkg RWD
VIN# JTHCE1BL4E5020157 - 2014 Lexus GS 350 Premium Pkg AWD
VIN# JTHBS1BL8HA002129 - 2017 Lexus GS 450h F-Sport Pkg RWD
mkmckinley (02-22-20)
Old 02-21-20, 06:58 PM
  #37
Zsikd
Zsikd's Avatar
I can attest to this. When shopping for a car (I wanted a GS but did not really plan on purchasing one till my lease was over. Long story short - I found it and purchased it. AFTER buying it I realized I had somewhat of a gem (the luxury edition). I drove the car back home for 10+ hours straight and I felt VERY comfortable. After long days of work, sitting in the luxury seats definitely feels relaxing when compared to the F-Sport (buddy has one and I can tell a difference simply because I drive a lot and am very particular about things). Get the lux edition if you want a smooth ride, AVS, but also have the ability to use S+ when you want and need it.
The following 2 users liked this post by Zsikd:
Im2bz2p345 (02-22-20), signdetres (02-21-20)
Old 04-06-20, 05:29 AM
  #38
Chaos236
Chaos236's Avatar
I have first hand experience with the standard 10 way adjustable base seats and the 18 way semi-aniline lux seats.
I swapped the base seats for the lux last year:
https://www.clublexus.com/forums/gs-...uxury-mod.html
The difference for me was night and day. The leather on the base 10 way adjustable seats was harder and I found them uncomfortable after 2+ hours driving, yes my butt would hurt from the seats sometimes.
The adjustments on the lux seats allow me to get the perfect fit, I didn't know I needed those adjustments until I had them.
On top of that the semi-aneline leather is noticeably softer. Now I can do long drives and my butt doesn't hurt.
Any future Lexus I ever own I will settle for nothing less than semi-aniline lux seats.
Of course there are many reason to buy one car over another and not just the seats.
I also have the f-sport front bumper, GS F tail lights, other nice exterior upgrades, and AVS. So I get the best of both the lux seats and the f-sport/sportier exterior styling.
Pics please!
cssnms
LX - 3rd Gen (2008-2021)
14
07-20-20 12:35 PM
sayow
07-26-16 10:44 PM
dangerdog
02-23-14 06:13 PM
Stefwilli
09-23-09 08:39 PM
iampraneel
07-16-05 12:59 PM
Quick Reply: Lux Pkg vs F Sport
