Peeled caliper paint now what to do?
@bclexus Because Burnt Copper is not available in Caliper Paint, only Engine Paint. Only differences I saw was Engine Paint is good up to 650F where as caliper paint is good all the way to 900F. I don't think my caliper will get anywhere near 650F they way I drive, I don't brake hard or ride my brakes. FWIW, it used the exact same VHT engine paint and clear as Davian and I have no issues at all. I actually didn't do the painting. My mechanic did. He said there is a special technique to do it correctly. And it takes 1-2 days so the paint cure properly before putting on the decals. I didn't do primer either. I believe he put on 3 coats (waiting a few hours in between each coat on a warm day last year). After paint cure for at least 48 hours, then he put on decal very carefully. Then 2 coats of clear on top of the decal.
I think you should just scrap your entire plan and go back to black calipers. Put back on your OEM wheels and ship those Velgens to me!
J/K... it looks to me that the paint did not adhere to the surface of the caliper, so that begs the question... how did you clean the calipers? Did you do an IPA wipe down to remove any oils and other contaminants? How did you clean the calipers after sanding? There's obviously something left on the surface of the caliper that prevented the paint from adhering.
Tell us more.
Tell us more.
Tell us more.
Tell us more.
Here's a good video of someone doing a thorough job of prepping, priming and then painting the calipers, and applying the vinyl decal and then the clearcoat.
Tell us more.
Tell us more.
I used soap and water with a tooth brush and brushed away, dried it down then sanded it with 800 grit sandpaper. Wiped it down with some IPA dried it then proceeded to coating with Primer 2 coats waiting about 10 to 15 minutes between coats. Did the same with the paint and gloss. Maybe I don't have the spraying technique down. But yeah that's pretty much how I prepped it.
These are the vht flameproof instructions.
"EXTREMELY IMPORTANT- After paint is completely dry, it must be cured to substantially increase the durability of the finish and enhance chemical resistance. See curing for details.Curing
Off the Vehicle:
Bake at 250F for 30 minutes, then let cool for 30 minutes. Bake at 400F for 30 minutes, then let cool for 30 minutes. Bake at 600F for 30 minutes, then let cool for 30 minutes. Caution: Do not exceed the heat tolerance of least heat tolerant part. Finish is not chemical resistant until cured.
On the Vehicle:
Run at idle for 10 minutes, then cool for 20 minutes. Run at idle for 20 minutes, then cool for 20 minutes. Run under normal operating conditions for 30 minutes.
Finish is not chemical resistant until cured."
I did the on the vehicle curing instructions, sort of, I just drove the car for 30 minutes, and had no issues. Until the paint is cured you should not be touching it at all with decals or otherwise.
Because you went does to bare metal curing is even more important.
Looks like the primer did not cure enough before you added the paint. I used the VHT Flameproof Orange and Clear on mine but did not use any primer. I cleaned the calipers with VHT Caliper cleaner first then wiped them down and allowed them to dry..I did not sand them. I waited a week before adding the decals and then did 3 coats of clear after. No issues.
Hello everyone! I painted my calipers a couple of days ago did everything right hopefully. Cleaned the calipers thoroughly then 2 coats of primer, 3 coats of paint, then 2 coats of gloss. Two days gone by and I got my decals so I decided to put them on. I watched a couple of videos and looks like you put it on and peel off the film part and its done. Not in my case i did the same thing and peeled off very slowly and this what happened! I'm freakin pissed off cause I don't want to go through the whole process again. What would you guys do? Do I have to re do the whole caliper or just that one area? Plus how to you put on the decal without it peeling the paint? Am I doing something wrong? Please advise.
RichKnecht (02-21-20)
I used the VHT burnt copper engine paint, no primer, over a year ago and have had no issues or flaking off, did not sand between coats, your calipers will never get anywhere near 650deg even if you track it. 660degrees melts aluminum so your wheels will start melting if your calipers are getting that hot.
I would just spray over the existing coat first with a new can and see what happens, hold off on the decals.
Mikey100
Automotive Care & Detailing
01-16-12 08:15 PM
