Sub for a gs350
I had a 2013 gs350 that i put a alpine mrv m500 and a 10 JLAudio w6. Now i bought 2018 f sport with ML. Does anybody know if i can tap into the oem sub like i did in my 2013
I don't see why you couldn't tap the wire for frequency. The only issue you'll have is the factory sub has a much higher frequency range than your JL, so your sound will be muddy without a crossover.
You can tap into the sub wiring from the ML amp. It will be a different wire compared to the Non ML GS. I believe your installer probably tapped into the sub wiring by the factory amp.
