Question regarding swift springs and coil over
Right now I run swift springs with stock shocks
Will Megan racing coil over perform better or worse
experts chime in
experts chime in
I think coil overs will perform better. When you lower a car with springs, you are compressing the struts, therefore shortening travel, which will affect handling and ride quality. This can also cause premature failure of the shocks.With coil overs, when you adjust ride height, shock travel remains the same as you are not adjusting height by shortening the spring, but the length of the strut assembly itself.
snaggle
Suspension and Brakes
12
09-07-12 07:49 AM
