Tire pressure warning system
Today i initialize the tire pressure warning system and when it was done Lf was 35 RF 36 rl 36 and rr 35. Does that mean the tire guy put the wrong tire on the rim or the tpms is
2018 f sport gs
2018 f sport gs
Tire pressures can change 1 psi or more by just having the sun shining on them for a few minutes. All your tires are within 1 psi of one another...
Also the Lexus system likes to round up, since there are no decimal points on the display.
All this is normal nothing to worry about.
I think you miss understood what the recalibrate button does. It sets a new default value from what is in their respective tires. So those values you listed in the OP will be the new set point.
Byprodrive (03-28-20)
I like having my tires set the same side to side also. The way I do it is first to fill all four tires a couple psi over what I want them to be when cold. After the car sets in a dark garage overnight I tweak all four tires down to within ½ psi of where I ultimately want them when cold using a digital tire pressure gauge calibrated to 1% with 0.1 psi display resolution. Then I'll use (drive) the car for a day, keeping an eye on the car's tire pressure display to see how all four tires react to increasing the psi due to driving and the sun's radiant heat. Chances are all four tires will react as expected to driving and the sun's affects. If they do, I'll leave all four tires as-is at ½ psi above where I first wanted the air pressure set. If any one or two tires look like they are not equal to the other side's tire I'll go check all four tires again after the car has been garaged for ~12 hours in the dark garage. The two things that I've found which need to happen prior to tweaking the tire air pressure is: (1) the car needs to not be driven for a minimum of 10 hours, and (2) the car must be in a dark garage...meaning no sunlight radiation to artificially affect the tire pressure.
What i should of ask is when you you reset the tpms does it have a set point like 35 in the front and 36 in the back or is it at what ever i have the psi when i push reset
I actually would have been really impressed if the GS self regulated the tire pressure so that it was equal across all four tires. Betcha Tesla’s do that. Just kidding, I was shaking my head reading this thread at first until Peasodos cleared everything up. The reset button does nothing more than turn off a light. No magic tire equalization/regulation system here. If such a thing did exist, Peasodos would have already had it on.
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/600x544/powdercoated_beadlock_wheel_600_600x544_3a9572f45d71115f9a7aca091a0554dac05a553e.jpg)
I hope we are talking about the same thing.
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/566x213/tpms_8114fa3e86593571b41b78a94bc8563943bb7956.jpg)
Seriously. I stand corrected. Don't know why I would want different tire inflation levels in my four tires, I would tend to want them all the same pressure, but good to know.
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/35x20/1_whistling2_c376c2ae0405a1b7fb481716548215b4d746fa1a.gif)
signdetres (04-01-20)
