Car sitting during quarantine
I will be working from home for at least the next 30 days, and I havent driven my car in about 3-weeks. There's no real need for me to drive the GS, and whenever i need to drive to the grocery store I use my truck because it's easier to get to in the garage. In any case, a few years ago i went on vacation for about 2-weeks and when i returned home I had to use jumper cables to start my car. Do I need to start my car every week or so, or can I just let it sit for the next month?
Measured (04-01-20)
Thanks for the replies all. Ill ssee what happens after 2-weeks. The time i mentioned about the car needing to be jumped, i think the battery was on its way out, and i have since replaced it with a new one (last year), so i think ill be ok. I just wanted to make sure that leaving a car sitting for a few weeks wouldnt be a bad thing.
Definitely get a trickle charger. I rarely drive mine even before this whole mess. It's always on charger, never have any issues with the battery. I even charge my other cars now that we never driven anywhere.
I fired mine up and let it run a while over the weekend when I washed it.
It will likely stay clean longer than it ever has before.
Just drive around the neighborhood for 15-20 minutes once or twice a week. Drive it when it's time to buy groceries.
Not something I worry about with my GS (even during quarantine), but it’s been a concern for years with my 1993 Seville which is a weekend car (albeit a very different beast and set of issues from a GS.) Some things to be concerned with when cars sit for extended periods (esp. in cold temps, which many of us are still in):
- Dead battery
- Bald spots on tires
- Engine starved for oil for longer periods upon startup due to oil pooling at the bottom
- Fuel separation
- Rust on rotor surfaces that turns to pitting, amongst other rust issues
- Dry rot and separation of rubber components/tubes/gaskets
My Seville stays exclusively garaged so many of these concerns are mitigated or eliminated, but if your car is sitting outside particularly in cold temps I personally wouldn’t let it sit for more than a week especially if it’s rained.
- Dead battery
- Fuel separation
jonathancl (04-03-20)
Just curious. Last week was my last day of work because of the shelter in place order. I don't know how long this will last but I won't be able to go back to work for another two month. I'll be driving to the grocery stores for essential needs but that's the only driving I'll be doing for the next two month. Given I won't be driving everyday, how can I make sure my car stays healthy? Cause cars are meant to be driven, I don't want my car to just sit and only driven a couple of blocks to the grocery store. Plus I'm not suppose to drive anywhere during the shelter in place order. Any advice?
Stay safe everyone!
Stay safe everyone!
Stay safe everyone!
Stay safe everyone!
davian112 (04-06-20)
Take a drive once a week or so and drive around for 15-20 minutes, maybe 5-6 miles around your neighborhood. That will keep the battery fully charged and fluids circulated even though the engine, transmission and fluids will not reach their normal operating temperature in such a short driving time. Every time you crank the engine the battery is loaded down briefly with an heavy inductive load - that is why you should drive around a little and let the battery fully charge back up.
Stay safe everyone!
Stay safe everyone!
