Corroding (+) battery clamp
Has anyone had the issue of the (+) battery clamp corroding? I've cleaned mine off two weeks ago and the greenish corrosion seems to be coming back. I did apply come vaseline/waterproof grease to it but no luck. I seem to have good ground and car runs fine so not sure what is causing it. I might end up replacing the terminal completely but was curious how others addressed this first.
EDIT: Did you find all the grounds and check them indiviually?
In terms of car runs fine, usually the warmer weather you`re not going to need alot of amperage to start.
diamondmit
04-02-09 02:17 PM
