Diode Dynamics SS3 LED Fog Light Kit for 2013-2015 Lexus GS350
Old 09-19-20, 10:45 PM
  #31
NashM
NashM's Avatar
Peasodos I need your expertise, I am doing the GSF tail-light conversion. There are two different part Numbers with a 45$ dollar difference in price. Do you know if the difference is a big one?
LENS & BODY, REAR COMBINATION LAMP, LEFT
Part Number: 8156130E20
and
This Fits Your 2016 Lexus GS F 5.0L AT
Part Number: 8156130E10
Old 09-19-20, 10:47 PM
  #32
NashM
NashM's Avatar
The attention I get is amazing, also I don’t blind anyone (thanks to you) so there’s no guilt
Diode Dynamics (09-21-20)
Old 09-19-20, 10:53 PM
  #33
NashM
NashM's Avatar
ALSO, Diode dynamite SS3 lens are interchangeable, all I have to do is buy the yellow lens and swap if I want. OR now they have lens covers way more quicker. I suggest to Anyone to go PRO power level regardless of beam pattern or color.
Old 09-19-20, 11:02 PM
  #34
peasodos
peasodos's Avatar
Received 2,228 Likes on 1,450 Posts
and
81561-30E10
Is what I used. As far as I know the only difference in the 2016+ tails was the one with chrome accent, regular GS and the one with Black chrome accent GS F. Maybe they gave later models a newer part number but didn't really make any changes. Lexus/Toyota does this with other parts, same exact part just change the number after a few years.
NashM (09-19-20)
Old 01-28-24, 10:13 PM
  #35
EAST
EAST's Avatar
Originally Posted by JoshIS408
Hi Pesados,
Do you know if these would work with the 16+ F-Sport foglight garnishes
Thanks
~ Josh V.
I know this is an old thread, but I had this same question.
I was originally going to install the Elite kit (Type B) from diode dynamics and be happy. I happened to have a set of regular flat SS3 Sports and made the mistake of comparing them to the Elites. The SS3 Sports throw a taller and wider beam than the Elites and were slightly brighter in spots. The Elites are more consistent and even.
Anyways, because of this thread I went ahead and also got a set of Pros to compare.
Top is Elite, middle is Sport, bottom is Pro. This is about 6 ft from the wall corner. These are the lights without the garnish in front.
Unfortunately, the 2016+ fog light garnishes block some of the lens, and you end up loosing a lot of light (around 40%) for the SS3s. The beam size and pattern itself is the same, it just becomes dimmer with the garnish in front.
Crude example:
The Elites don't suffer this because the optic is already short and centered on the light. So no light cannons for the 2016+ . I'll be installing the Elites.
07LexusGuy
RX - 3rd Gen (2010-2015)
97
12-15-19 06:14 PM
mrkwinning
08-09-18 11:10 PM
asurada
07-23-16 01:48 AM
Mesh704
10-15-14 02:55 PM
triquynh
08-15-14 03:49 PM
Quick Reply: Diode Dynamics SS3 LED Fog Light Kit for 2013-2015 Lexus GS350
