Diode Dynamics SS3 LED Fog Light Kit for 2013-2015 Lexus GS350
Hello Club Lexus members, I have a 2013 GS350 F-Sport AWD. I bought these fog-lights, I am wondering if they would work with the aftermarket bezel kits available for our cars off eBay.
eBay link- https://www.ebay.com/itm/Fog-Light-S....c100752.m1982
Diode Dynamics SS3 LED link -https://www.diodedynamics.com/ss3-led-fog-light-kit-for-2013-2015-lexus-gs350.html
thank you for your input, there the same 3in size as the morimoto. I picked the driver PRO white. The fog lights available in yellow and white have a shorter length but wider throw. ill add the pics when I'm finished with install, delivery is estimated 2weeks away
Diode Dynamics (05-18-20)
Fog lights should always be angled down, don't want to blind oncoming traffic. Looks like these adjust with two screws, one on each side, a bit of a PITA compared to oem that just have one adjustment for up/down.
I would install these in the bracket on a level surface and then slightly angle it down from the level position, then tighten up the screws.
subbed, I am planning on getting these too
Also, what harness are you going to use and where are you going to draw the power from with the higher wattage Pro set? On a related note, do you happen to know what the lumen output is of our stock headlights? Is there any chance that the PRO would be brighter than the stock headlights? Thanks.
What's your thinking behind purchasing the DRIVER pro for your fogs rather than the designated fog ones? I'm trying to make a decision, so your input would be great!
Neophyte2b (05-16-20)
Do you think it would be a good idea to go with the SPORT for the lower cut-off if I'm installing it in my GS, or do you feel that the fogs will be low enough on the GS that I won't even need to worry about the taller vertical light scatter from the PRO? Thanks.
