Spinning wheel lug
Spinning wheel lug
I was removing one of my wheels when one lug began spinning. I've spent hours trying to drill it out, but I have to buy a new drill because the one I used broke. I am able to get a small Vise-Grip on the inside cap of the lug, but with any pressure it pops off. Would a butane or MAPP torch work? The wheel is scratched, of course, and I'm planning on a new hub, but I'd like to avoid further damage. Any ideas about how to get this sucker off? Thanks!
Wait, did you round off the lug nut?
If so, hammer on a 20mm or 19mm socket and then you should be able to get it off. Mind you, doing this will ruin the socket.
The problem was/is the lug, not the lug nut. The lug itself has moved out of the splined hole in the hub that holds it in place. I can still get a socket on the nut, but I can’t find a way to hold the back of the lug tight while I turn the nut, so the whole thing spins. Even a small Vise-Grip, which is all I can slip between the wheel and the hub, tightened as much as possible, still can’t hold it. I’ve drilled the center, but they hasn’t yet worked.
I had the same issue the other week but it was on a spacer. You’re really just going to have to keep spinning the lug nut with an impact gun to shave down the the threads and pull the wheel off with brute force. Its a really slow and painful process.
Finally, after 3 hours with an air chisel, I was able to muscle the wheel off. The stub is still on the hub (cool alliteration). I anticipated needing a new hub anyway, ordered it a few days ago. I may also need a replacement wheel, although mine can possibly be repaired. I also replaced all the lugs on each wheel to start the clock again. What a pain.
Johnhav430
12-12-19 05:17 AM
UptownGS
Wheels, Tires & Brakes Forum
07-09-05 02:46 PM
