Interior Center Fan
7th Gear
Interior Center Fan
I just noticed this yesterday, but the fans in the center console makes this whirring/humming noise when it's turned on. You can hear it coming from the center console/stereo controls. It will make that noise as long as it's on. It's a CPO 2015 GS 350 F-SPORT that still has an active warranty. Would Lexus be able to diagnose this and replace it under warranty?
I've tried these basic troubleshootings:
- Turn on A/C (recirculation on), no noise.
- Recirculation off. Problem persists
- Remove cabin air filter and check blower fan. Nothing is out of ordinary.
- Compared it to my 2014 GS 350 and it was normal
2015 is SD card based navigation, no disk hard drive and one less cooling fan that 2013/2014.
If the fan is making odd noises it may be failing. My stock 2013 head unit had a cooling fan that was making a clicking noise. I took apart the radio removed the fan, connect it to power and confirmed the issue, replaced with a fan purchased on Amazon.
This is the defective fan making the clicking noise.
This is the location of the defective fan.
Here is pics when I fixed the problem, some disassembly required:
CharlieH
RX - 1st Gen (1999-2003)
11-05-12 06:19 AM
