Concerns 2017 gs350 fsport
Hello this is my first post here as I’m new to this forum
I just recently purchased a CPO 2017 Gs350(caviar/rioja)
i bought the car with 32k miles
and I have a couple concerns and was wondering if anyone else had the same issues
for starters
my car has the slightest squeal when it’s going under 30mph and usually when I press the brakes it goes away and then it makes a louder squeal as it comes down speed
it’s not squeak but more a creek
also it is was noted my water pump and gasket assembly was replaced by the selling dealership with the 30k service they performed
it had a coolant leak apparently
but my ac doesn’t blow ice cold unless it’s moving
Additionally my backseat leather have this glisten to them in the little pores it almost looks like glitter or glass in the little holes on the leather
then with all this concern I was having
I looked up the vin on the Lexus maintenance look-up
it shows a few things which raises more concern
at
5k miles the entire front and back seats were all taken out to fix a rattle noise with the sunroof
then at 15k it stated this
“ ~GUEST STATES THAT THE VEHICLE MAKES A CLICKING NOISE FROM THE FRONT WHEELS WHEN TURNING ~|~FOUND ROTORS AND HUBS BINDING”
then at 20k the owner took it back cause the ac had a bad smell
and I’m experience the same the first 30 seconds my air starts recirculating
maybe I’m paranoid but I also have an appointment with the selling dealer to have a couple of my concerns looked at Next week
for starters
at
Out of everything on your list, this one is normal lol. When new, all 4 seats have glittery/sparkly material inside the perforations that glisten in certain lighting. I think over time the little holes in the seats eventually fill up with dirt/grime/dust and diminish the sparkly effect. The backseats on your car were probably used very little and still have the effect.
Shay575 (06-23-20)
Could the leather be vacuum to get those glitter or glass out?
Brake squeal is normal. A/C should be looked at for sure.
All mechanical items should be brought to the selling dealer first. When I purchased my CPO before, the other dealers suggested talk to the selling dealer first before their place.
Still if not fixed, discuss with the selling dealer's General Sales Manager to address the issue.
Last resort is to call the Lexus Corp number to file a complain.
Shay575 (06-23-20)
So true, I encountered a number of CPO that shouldn't be CPO vehicles at all.
Shay575 (06-23-20)
Welcome to the forum and congrats on the purchase! Your car is still under the original FULL bumper to bumper warranty until 2021 so any issues you have, bring to the dealer to address for free under the original 4yr/50k warranty. If your selling dealership isn't helpful, you can go to any other Lexus dealership who may be more helpful.
- Brake squeal is a tough one which you may have to live with depending on your tolerance for addressing it or trying different things. So many threads on F-Sport brake squeal on the 4GS forum. If you have a RWD F-Sport, some folks had success with changing out the OEM front rotors to a once piece vs the original two piece rotors. Keep in mind that many people do NOT have success and have to live with some clicking, squeaking or squealing noises.
- Have the dealership take a look at the A/C once again. Sit with a technician or if they have another GS or comparable Lexus sedan (e.g. ES350 or IS350) ask them to test the A/C in those cars to compare. My '13 has never had an A/C problem and its approaching 9yrs old.
Shay575 (06-23-20)
for starters
Could be your pads are low and the feelers (low wear indicators) are touching the disc (normal) making a squeal/creak sound.
First I heard of a coolant with the GS.
That is odd. Definitely a possible warranty issue. I had my water pump replaced in my Infiniti a few years ago and the AC compressor had to be removed, hence refrigerant had to be removed and replaced. Even though the refrigerant was brought back to spec, it wasn't cooling well enough for me. Bought a bottle of refrigerant from Wally World and pumped a little more in... what a difference... that AC worked like a champ from there on.
Normal... my 18 with 16K still has sparklies on the back seat cushion.
at
Sunroof seal is fairly common for a rattle, some have it some don't, an easy and inexpensive fix. There's a thread on it.
Normal with 2 piece rotors, especially noticeable going through the drive thru lanes.It stopped after a while, or I just got accustomed to it.
Luckily I don't have that issue, but a few others have experienced this, not many, but a few... can't remember the fix. Easy to check...did you check the cabin filter? Might be dirty and causing the smell.
for starters
at
Shay575 (06-23-20)
Little off topic but, do you know if this car has ever been in an accident? As for the sunroof rattle, a new gasket is not always the fix such as my 18 has. One member here had mentioned his sunroof hardware mounting bolts were actually loose. My tech had stated you can essentially open other rattle issues when removing a headliner which I tend to agree with. Good luck with your 17!
Shay575 (06-23-20)
