check srs sytem light came on
hey guys so i was disconnecting my gs350 motion bypass kit and now when i put everything back to stock a check srs air bag systen light came on?
Does anybody have any pics of how behind the radio suppose to be just to double check or no what it could be
If you have the radio disconnected and turn the car on you might temporarily get this warning because there is a passenger airbag light on the radio itself, if that's disconnected system detects a fault in the SRS system, but should clear by itself when you put everything back. try turning off the car wait 5-10 minutes, disconnect the negative on the battery, wait 5-10 minutes, reconnect, and see if the warning goes away.
websurfer (06-24-20)
I disconnected the negative battery overnight and left it to see if that work still the light came on do you have a pic of behind the radio to make sure I connect everything back everything is working which is weird
here is a pic of everything behind
