Break squeal
Break squeal
Have a 2015 gs 450 rwd.. had front pads replaced about 10k miles ago from firestone with oem pads and had front rotors resurfaced. The front breaks squeal at different times. Sometimes with cold start sometimes hours after driving.
I know there was talks about this in the past but what should I do? Currently front breaks are at 9mm
It probably would be better to replace your rotors and pads. The resurfacing is probably the problem. The rotors may be shot and it wasn't cost effective to resurface. Resurfacing has to be done with precision and the rotors are probably fatigued to begin with. The thickness has to be same all around and I doubt they were machined correctly. "Brake"....edit the title so it can be linked to related topics.
