Here is my RWD setup, all purchased from Skylar at Wheelwell with promotion codes and I saved a ton of money, nearly 40% off. No brake squeal at all with aftermarket rotors and Akebono pads. It stops like OEM, even with the lack of surface area from the drilled/slotted rotors and I have 20x10 and 20x11 3-Piece Forged Wheels,. The brake spongy feeling is also gone, but that improvement of the sponge feeling is also aided by the FIGS front LCA bushings. These wheels are very heavy and the new rotors and FIGS really helps to prevent nose diving.
- Stoptech Front Drilled/Slotted Rotors
Front Left 127.44204L
Front Right 127.44205R
- Stoptech Rear Drilled/Slotted Rotors
Right Rear 127.44189R
Left Rear 127.44189L
- Stoptech Stainless Steel Brake Lines
Front 950.44003
Rear 950.44504
- Akebono ACT 118 Front Ceramic Brake Pads - Rear pads are OEM and still have quite a bit of life left. - Motul Dot 3 & 4 Brake Fluid
Here is my setup, all purchased from Skylar at Wheelwell with promotion codes and I saved a ton of money, nearly 40% off. No brake squeal at all with aftermarket rotors and Akebono pads. It stops like OEM, even with the lack of surface area from the drilled/slotted rotors and I have 20x10 and 20x11 3-Piece Forged Wheels,. The brake spongy feeling is also gone, but that improvement of the sponge feeling is also aided by the FIGS front LCA bushings.
Front 950.44003
Rear 950.44504
Front 950.44003
Rear 950.44504
tungo I checked the WheelWell site. It doesn't show that this would fit a 2016. Can anyone confirm fitment?
Front 950.44003
Rear 950.44504
Do you happen to know if I will be able to use the promotion codes? Where did you get them?
