Backup Camera intermittent
The back up camera on my 2015 GS 350 works one day, not the next. Screen is just black when I put into reverse. Every other function on the screen works - Navigation, etc. The only issue is sometimes, when I put the car in reverse, the screen where the camera feed would be is black. I noticed that if I start the car and it works, it will work again and again during that same trip. If I start the car and it does not work, it will not work during that entire trip. The issue occurs every week. At least once per week it will not work. Sometimes it goes days without working, then it works for days at a time. Dealer upgraded the firmware, and that helped for a while, but now the same issue again. They can't figure it out. Anyone have a similar issue and find a fix?
Make sure it's clean, and nothing looks lose. You can spray it with electrical cleanser and put back together. It helped mine. You can also use WD40, it's safe for electronics. I think moisture can get through and cause issues.
I have the exact same problem. This is specially happening during winter times - can someone please post some instructions or pictures on how to access the harness to access the camera?
Any updates on this issue? I seem to notice something similar, it only occurs after I open and close the trunk. I can then fix the issue if I open and close the trunk again.
Sometomes there is interference on the signal when the camera appears on the screen. I'm assuming the issue is easily accessible after removing the carpet liner and I can just check out the connector but curious if anyone else tackled this. Thanks!
I am having this problem in my 2016 GS 200T. It is difficult to pinpoint the cause. I did some research and here are my findings.
The steps I would follow (in order from low to high involvement):
1. Make sure all software/firmware is up to date.
2. Check if the system is throwing any code. If it is, diagnose, fix, and clear the code.
3. Check for dirt, moisture, and loose connections from the camera all the way through the head unit. If opening/closing the trunk causes or fixes the issue, there might be a connection problem somewhere in the trunk.
See this LS (2007-2017) thread https://www.clublexus.com/forums/ls-...ra-glitch.html , and in particular the following post:
Here is a useful video on fixing this issue in a Nissan:
I can tell you a similar story with my 2005 LS 430 which I bought as CPO in 2008. Within couple of months of my purchase, I had similar issue that camera would go black some times. Took it to dealership in Richmond, VA and they changed the camera under warranty. Told me that cost was $1300 but Lexus took care of it. This did not solve the problem so I was back at the dealership within couple of weeks. This time they changed the computer which controls the camera. Told me again that it was $1700 fix, but was covered under warranty. This still did not fix the issue. So on the third attempt they kept the vehicle for five days and when I finally picked the vehicle, I asked them what was actually wrong with the vehicle. I was told there was a loose connector behind the head unit which randomly would work most of the times and on some occasions would show bad connection and hence black screen. I drove that vehicle for 6 1/2 more years (200K plus miles) after this, never had an issue again.
I certainly believe that there is a loose connection somewhere. Finding that loose connection might be the most difficult part. Once found, fix is very simple then.
3. Check for dirt, moisture, and loose connections from the camera all the way through the head unit. If opening/closing the trunk creates or fixes the issue, there might be a connection problem somewhere in the trunk.
See this LS (2007-2017) thread https://www.clublexus.com/forums/new...eply&p=9480114 , and in particular the following post:
https://www.youtube.com/watch?v=A4csDRWxVtU
Opening/closing the trunk does not make any difference in my case. For your case, the Nissan video I posted might be helpful.
