Dead battery mechanical key won't open door How to open pass thru from inside trunk?
Title says it. Lexus replaced the door acttivator on drivers side and the mechanical key will not turn to open the door.. Going to try and go through the trunk but don't see how to open the pass thru......Thanks
Deleted as I misunderstood the original question.
Yep, you can't go in from the trunk. Had to call a locksmith. Used a little pump up bladder in the front passenger door to open it a little, slid in a grabbing tool, opened in less than 2 minutes. Will be going back to Lexus since they must have screwed up the manual unlock when they replaced the actuator.
Thanks all
Thanks all
Thanks all
Thanks all
Does that bend the top of the door frame outward? I watched a youtube video and it slightly bent the door frame. Then the guy just opened it put his knee on the edge of the door, grabbed top of the door and bent it back.
Check the top edge of the door if it sits plush with the b-pillar or stick out a little.
Dealer should pay for this.
When I bought mine, I found the mechanical key did not work, and there was a service record for the driver door lock actuator, which means they didn't reinstall the manual key link correctly.
Behind the physical key is a shaft with a cross fitting at the end that must be carefully fitted into the cross socket on the lock mechanism. It's easy to miss, easy to get wrong, unless you test.
If you don't have it on the driver door handle, previous owner must have bought the cover from the passenger side and replaced the driver side that originally had the key hole. I bet the original key slot is still there under the cover. This is a dumb cosmetic mod because when the battery dies you won't be able to open the car if it's locked.
As for the door the driver door has a key lock.
Unfortunately had this happen to me today. Completely dead battery. Mechanical was not working on driver door but was working on trunk. I had replaced the actuator on the drivers side door myself about a year ago so I’m assuming I had messed something up myself when I did that in regards to the mechanical door opening.
Ended up needing to get a locksmith to use the air bladder to get into the car. Luckily the door doesn’t seem to be too bent out of wack. Don’t hear any air leaking through and weather stripping seems intact.
anyone have a diagram or video on how the manual key locking mechanism hooks up to the actuator?
lth40555
01-06-12 08:31 AM
