Check Auto Headlight Leveling System
I lowered my car about a month ago and never got around to fixing this. I had this "Check Auto Headlight Leveling System" on for a month and do notice my headlights are aimed too low. I was wondering how to fix this issue. I assume adjusting the headlight height will make the light go away on the dash? I broke my front passenger ABS sensor in the process of lowering the car, I'm in the works of getting a new sensor. I have ABS light and traction control light on. I'm not sure if that ABS sensor has anything to do with the headlight leveling system. I drive a 2013 GS 350
ayudame friends
I'm not sure about thet abs sensor but you can manually adjust your headlights
Here's a post on how to do that
https://www.clublexus.com/forums/gs-...ml#post7558711
initial (11-27-20)
Check to see if you have ripped the wiring harness that goes to the headlight itself or something may be loose from the headlamp. There might be a chance it is a loose plug on the headlight itself. Check both headlamps plugs and the ends.
initial (11-27-20)
I will check that when it stops raining. It's been raining the last 2 days and will rain for the next week. I unfortunately do not have a garage lol. I read in a few threads that lowering the car will cause this sensor to go off since the headlights are aimed too low. I lwoered the car roughly 2.75 inches all around.
I believe the headlight level sensor is on the driver rear arm. It was not in the way when I installed my coilover, but your mileage my vary. My headlights are aimed very low, but never had the dash warning, I don't think the car is tell you the headlights are low. I think something happened to wiring of the sensor or the sensor itself.
initial (11-28-20)
initial (11-29-20)
Good news friends. I dropped it off to my friend at Toyota and he took a look at it since the weather is still pretty bad here. He manually adjusted my headlights then adjusted leveling system. So now my headlights are perfect now. I can finally see at night haha ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
He told me since the car was significantly lowered, the leveling system couldn't compensate enough so a minor adjustment corrected everything.
I measured from tire to fender. I lowered the car 2.75 inches all around. I could've went even lower, but another quarter inch and my car would not clear the lifts at the Lexus and Toyota dealerships. The car literally barely clears the lifts.
RRocket
02-16-06 08:08 AM
