2021 ES350 FSPORT Vs 2019 GS350 FSPORT - I own Both!
Well the ES is mainly for my dad and he drives under the speed limit so the ES is perfectly fine for that. ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
On another note, I just ripped around in my GS just now in Sport + and going around on ramps at 85 mph. This is thing is nuts! Didn't remember my 2014 being this crazy. What did they do to this thing?! lol
I'm not quite sure I follow your question about the customized mode, LexusGSboy.
I set up my custom mode to have the Sport suspension setting but leave everything else normal. I set it up once and never have to change it again.
Yeah same with my Custom mode, just sport suspension and normal everything else.
My initial assumption before setting it was you'd customize it and it would stay. I set it, drove that way for a while. Week or two later I went back in and everything was reset to Normal. I reset the chassis to Sport, checked it a few days later - it was still sport so I assumed I either didn't set it right or thought that maybe (I couldn't remember) I had put it in Sport + or Eco or something and that by doing that, when I set it back to normal everything went back to normal. I never actually did any testing.
It had been in that setting (as far as I knew) and I just wasn't changing the modes thinking that it would wipe it out. The car went in for service and I was looking at something else so I sent in to look at the setting and again, everything was reset to Normal. I assumed it was either that the battery was disconnected for the service and it went away or the tech have changed the mode with the dial and wiped it out.
I'll have to play with it and see if I can figure out what makes the car go into a different mode. I only use one key fob so I don't think its that. I just assumed the custom settings didn't really "stick" permanently.
Interesting. I have mine set as I want it, and routinely flip through all of the modes but haven't ever had it erase my settings.
JDR76 (12-22-20)
So of course tonight when I tried to replicate it it wouldn't do it. Checked the setting when I first got in the car - Engine>Normal, Chassis>Sport, Climate>Normal. Put it in Sport + and did a run to the store. Parked, turned the car off.
Got back in and started the car. Car no longer in Sport + (this is normal right?) Checked the setting and Engine>Normal, Chassis>Sport, Climte>Normal. Pushes the **** and screen said "Customize" (or something similar).
All I know at this point is that on two occasions I thought everything was customized but when I went in and checked the setting everything was set back to normal. I'll keep an eye on it and see if I can figure out what's going on. At this point I'm going to assume it's somehow user error.
Thanks for confirming normal behavior for me!
All I know at this point is that on two occasions I thought everything was customized but when I went in and checked the setting everything was set back to normal. I'll keep an eye on it and see if I can figure out what's going on. At this point I'm going to assume it's somehow user error.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Mcb345
02-12-15 12:46 PM
Rexus300
03-23-13 09:46 AM
