Shaking at idle after driving
I have a 13 AWD with 113k. I’ve realized more so recently - after driving and coming to a stop, the car shakes for roughly few seconds as if it’s hesitating to stay on. Does not happen always. I changed sparked plugs at 100k. Always pump premium. No signs on the dash. Any ideas?
Bad gas, water pump, just few possibilities not sure
ive cycled through gas 2 times now - full to E, and still happens.
fuel pump recall? Although I’m not on the list under the VIN.
If possible, try an autoparts place for a free scan. Sometimes a code will be stored or pending and not show an "engine light"....
If you were close by, I have a scanner to monitor misfires while driving.
Spark plug coil boots should be replaced if possible when replacing spark plugs.
NatGen (12-20-20)
Try an Italian tune up... then report back.
NatGen (12-20-20)
Please report back. I'm starting to have this issue too. My GS is only at 63K though
NatGen (12-20-20)
I’ve driven it on the highway for 2+ hours straight. Still happens. Spark plug coil boots were not changed. I will connect the snap on tool and see what the problem is. Will report back once I find out. Thank you!
Clean the Throttle Body with CRC or with Toyota Plate Cleaner.
02-03-21 12:35 PM
